AC pressure sensor?
Old Jul 2, 2010 | 05:41 PM
volvolini's Avatar
Default AC pressure sensor?
Hi
I just got CEL on my S70 this morning, 2 codes: p0446 (Evaporative emissions control vent circuit low) and p0531 (ac pressure sensor circuit performance/range).
- had a cracked "j hose" and i was hoping that replacing it would take care of first code but it didnt?! What else can trigger this code?
-I did search on second code and no luck. My ac works when I first turn it on and it shuts off after few minutes. I thought this means bad clutch on compressor? but this code for ac pressure sensor makes me wonder if its something else? Which sensor is this, where is it located?
Any help would be greatly appreciated
Old Jul 4, 2010 | 08:06 AM
1. Is any of the other hoses by the fuel filter cracked? If not the evap valve can stick sometimes.
2. It could be the high pressure switch located behind the passenger headlight.
Old Jul 4, 2010 | 08:26 AM
volvolini's Avatar
Hoses were fine. Shut off valve was the problem. I replaced it. No more p0446 code.
I changed high pressure switch as well, nothing changed, i only have ac for first 5 minutes. I think i am going to replace ac compressor because clutch is probably gone and then see if code comes back.
thanks tech!
Old Jul 4, 2010 | 08:35 AM
To test the clutch to see if it is bad start the A/C and when it quits working check for power at the compressor. If you have power it is the clutch. If you have no power then it is something else.
Old Jul 4, 2010 | 05:31 PM
volvolini's Avatar
I just did that. Clutch is bad. Thanks! Now i am sure i need new compressor.
Old Jul 4, 2010 | 07:27 PM
If you are really handy you can reshim it. It is a pain but can be done.
bydand
2001-2013 model year XC70
47
Aug 4, 2025 04:52 PM
MntnDewMan
Apr 3, 2024 04:05 PM
ses_volvo
Sep 20, 2013 08:56 AM
brettboze
Mar 26, 2012 06:25 PM
STREETFIGHTER50
Mar 12, 2009 07:29 PM
