Acceleration Sensor
Old May 26, 2011 | 08:05 AM
chachouu's Avatar
Banned
Default Acceleration Sensor
where exactly is this part located in a 1998 S70
Old May 26, 2011 | 05:48 PM
Carrots's Avatar
Are you talking about the vertical acceleration sensor? That's mounted on the front of the engine cradle, right side. Little flat black square with a single wiring pigtail plugged into it. It's near the A/C compressor. This is used by the computer as part of the "spark knock" detection system. Basically, it's an accelerometer that lets the computer know if the suspected knocking from the knock sensor really was a knock or a jolt due to a hard bump in the road. If the computer gets a "knock" signal from the knock sensor at the same time as the vertical acceleration sensor signals a hard hit, it knows that it wasn't a knock. It prevents the computer from retarding the spark unnecessarily. It's kind of a Volvo quirk, but it helps the entire engine management system to be far more precise.
Old May 27, 2011 | 07:05 AM
chachouu's Avatar
Banned
So therefore i can replace it when I want.Not an emergency type of thing?
Old May 27, 2011 | 05:12 PM
Carrots's Avatar
No, not an emergency. But it will affect performance and mileage.
Old May 25, 2012 | 05:46 PM
alexs70glt's Avatar
Default accel sensor
here is a pic of the sensor. anyone know of the harnesss that attaches to it part number?
Old May 29, 2012 | 02:59 PM
AZvolvoMan's Avatar
So how can you tell that the sensor is bad, or its time to replace it?
Old Jun 8, 2012 | 04:35 AM
penlopehayek's Avatar
Professional version can be used in the analysis and writing video recording and playback of personal computers and statistical acceleration due to gravity, the functionality of the whole.
Analysis software for Windows is a free download from the storeroom α(This application language is Japanese.)
· Http://amonooki.web.fc2.com/program/canalyser.html
Recording
While you reflect on the monitor in real driving conditions the car-free, to be recorded.
Playback and
And immediately see the data were recorded, traveling, etc. can be useful for checking the gymkhana.
Statistics
You can see the statistics and data of maximum acceleration of gravity, making it ideal for measurement of performance, such as tires.
Warning functions and acceleration
Naraseru warning sound acceleration so that you set, and the practice of load transfer, these can be used up to eco-driving.
Video & analysis on a PC, write
By moving the data to the PC, and can be analyzed from the dedicated software, and export video. More detailed analysis can be embedded into the exported video travel videos.
※ It is recommended that you buy from can be confirmed to work with (If you wish to use) version and Windows version Perosnal.
volvorecycle
Jul 22, 2015 07:44 PM
chachouu
Jun 6, 2011 08:53 PM
rcsoundn1
Apr 5, 2009 01:19 PM
rcsoundn1
Mar 12, 2009 10:01 PM
Tengu
Feb 9, 2008 06:11 PM
