Accessories
Old Mar 23, 2020 | 09:09 PM
Halz99's Avatar
Default Accessories
All my symptoms(i.e., radio, a/c, mirrors). I replaced the ignition switch twice with no success. I’ve checked all fuses. Is there another possible problem and or fix.
Old Mar 24, 2020 | 07:42 AM
you'd need to check a wiring diagram for common circuit points - ie a ground, a relay and whether the CEM is in the circuit (CEMs have internal relays ) then start probing with VOM. Also you may want to inspect wire runs, particularly if you park where mice can get at the car (common issue here in the northeast).
McSpartan1227
Jan 15, 2020 02:04 PM
blu72
Aug 27, 2011 10:41 AM
Mary2214
Feb 26, 2008 11:31 PM
Eric
Jul 3, 2007 02:53 PM
haygoog
Jun 8, 2006 06:28 PM
