Advice on Better mileage?
Old Apr 11, 2020 | 05:24 AM
How the? Where the? WTF?!?'s Avatar
Default Advice on Better mileage?
Accepting any and all advice/diys for new car owner to help out with my gas mileage for my 98 volvo s70
Old Apr 11, 2020 | 07:46 AM
Subi-Doc's Avatar
Default Performance Chip Tuning
Performance Chip Tuning works with your ECM and adjust for two weeks . Add one to my S80 and I gained 3mpg and 3 lbs of boost.
Old Apr 11, 2020 | 08:39 AM
start with the basics - 1) make sure your car is in good tune - fresh cap/rotor/wires/plugs/intake air filter, use some injector cleaner like Techron or run premium brand name gas every 4th tankful to keep a clean fuel system, inspect the MAF/throttle body to make sure they are clean 2) make sure your car is running the correct weight oil, consider going synthetic. Owners manual (available online) will show weight for your climate. 3) add air pressure to your tires. You can easily run 36-39 PSI. 4) freshen fluids in the transmission. Drain fill automatic, gear oil in manuals. If you have a manual transmission, consider a synthetic gear oil like Redline. 5) turn off your AC except when needed 6) drive with a light foot. Read up on techniques "hypermilers" use. After that, you can consider ECU tunes that have a more advanced spark - but that will also require premium fuel. Buyer beware here - lots of unproven internet claims so do your research. Finally, some tests have shown premium gas can improve MPGs slightly but not enough to recover the price difference.
gentlejax2
May 20, 2011 11:31 PM
toha_70
Mar 26, 2011 10:08 PM
somethingsalty
Nov 3, 2009 08:09 PM
geminigongju76
Mar 17, 2008 11:25 AM
shelbylay
Oct 28, 2007 11:48 PM
