Anyone use ScanGauge?
Old Oct 28, 2005 | 11:13 AM
AaronD81's Avatar
Default Anyone use ScanGauge?
I just got mine and it seems to work well. Anyone have any input on how well it works in the long run? Any problems? For those that don't know it's a OBD II code reader and it also works as a trip meter and also have gauge readings.
Old Oct 28, 2005 | 09:24 PM
Default RE: Anyone use ScanGauge?
Haven't used it yet but keep us posted on how it works.
Old Oct 28, 2005 | 11:14 PM
AaronD81's Avatar
It seems to work well, but I just realized that half of it's function is to constantly measure vehicle stats and the OBDII port is in a bad location to do this. It would be much easier to keep permanently attacked it if was under the dash like most cars.
Old Oct 28, 2005 | 11:46 PM
Do you ever have people in the rear seat?
If not remove the console and Slide the OBD plug out of its spot. Then remove the rear ashtray from the console and then sit the monitor in the center so you can see it.
rspi
Jan 26, 2012 09:44 PM
VJZ
Aug 14, 2009 08:34 PM
boxpin
Jul 16, 2009 08:30 PM
2002s40
Dec 27, 2008 05:44 PM
m4gician
Jan 28, 2007 02:01 PM
