back up lights and signal lights
I have two problems I need the forums help with.
I have a 98 S70 and the backup lights do not work. The bulbs are good, fuse good. Could it be abackup switch? If so how do I get to it? Other suggestions?
The 2nd problem is when I try the left turn signal it flashes about 2-3 times faster than normal. The right signal flashes nornal as do the hazard warning lamps. What could cause this? Could it be the hazard warning switch/relay in the console? Other suggestions?
Your help is appreicated.
Guy
Guy
