bah. i need some help.
Old Nov 27, 2009 | 07:28 PM
thekoopa's Avatar
Default bah. i need some help.
My 98 s70 has been sputtering off and on for a few weeks. I thought maybe I have a clogged PCv system. Well today on my way home from work it completely stalled and the car turned off. I can start it right up again but I'm afraid to drive it home on the highway invade it happened again. What do you guys think is the problem is? Could a clogged PCB system do that or maybe a fuel pump or filter. Please help me out.
Old Nov 27, 2009 | 07:48 PM
Maybe fuel pump relay is bad.
Old Nov 27, 2009 | 10:05 PM
thekoopa's Avatar
Do they usually carry those at a local autoparts store or do you think I would have to order one? Also how hard is it to put in?
Old Nov 27, 2009 | 10:13 PM
The relay maybe. I would pull yours and open it up and look for bad solder joints.
Old Nov 27, 2009 | 10:15 PM
thekoopa's Avatar
I just realized how broken up my first post is. Sorry about that, I was trying type it out on my phone right when it happened. Where is the fuel pump relay located?
Old Nov 27, 2009 | 10:35 PM
Under the hood in the fuse box. You have to remove the 4 torxes 25 screws and then the cover. It should be a red relay. It should also say fuel pump relay on it.
Old Nov 27, 2009 | 10:38 PM
thekoopa's Avatar
Ok, I'll check it out tomorrow. Too dark to do anything now. Thanks for your help tech. You'll probably be hearing from tomorrow.
Old Nov 28, 2009 | 03:11 PM
thekoopa's Avatar
I pulled the relay out and the thing looks brand new inside. I was going through some maintenance records and the fuel filter was changed about 30k miles ago along with plugs and wires and distributor. Do you think that having a clogged PCV system would make my engine sputter and stall randomly? I drove my car for about 10 minutes today and no problem whatsoever.
edit: I didn't actually open up the relay because I wasn't sure if it's supposed to be opened. It looks like it's supposed to be sealed. Should I open it up and look inside. If so what's the best to open it without destroying it.
Old Nov 28, 2009 | 07:53 PM
Yes open the relay up. By where the pins are you can pop that cap off. Carefully use a small screwdriver and pop the cap off.
Old Nov 28, 2009 | 11:15 PM
thekoopa's Avatar
Looks clean. Contacts and solder marks look new
What else could it be
Old Nov 28, 2009 | 11:20 PM
Maybe fuel pump or something else. Is the check engine light on?
Old Nov 29, 2009 | 01:32 PM
thekoopa's Avatar
I wish the CEL would come on. Then I would have a clue about what's going on. Is it possible for the PCV system to do all of this?
Old Nov 29, 2009 | 06:01 PM
I doubt it.
Old Nov 30, 2009 | 08:22 PM
thekoopa's Avatar
Is it possible the relay is bad but just not showing any visible damage? I have no records of it ever being replaced. If you give me the word I'm going to order a new one. If that doesn't fix it, I guess I'll spend the money on the fuel pump.
Old Nov 30, 2009 | 08:27 PM
thekoopa's Avatar
Where do you guys order parts from?
Old Nov 30, 2009 | 08:37 PM
They can go bad and not show signs. But usually the solder joints crack.
Try FCPgroton.com for the relay.
Old Nov 30, 2009 | 08:45 PM
  #17
thekoopa's Avatar
Is it possible for fuel pumps to go bad over time? Wouldn't the car throw a code if the fuel pump was bad?
Old Nov 30, 2009 | 08:46 PM
  #18
No codes will be thrown. The pumps usually work or don't.
Old Nov 30, 2009 | 08:48 PM
  #19
thekoopa's Avatar
Alright, ordering the relay hopefully this will take care of it.
Old Nov 30, 2009 | 08:50 PM
  #20
I hope so to. I will wait to hear back from you.
