Bleeding air from brake lines - advice ??
Old Jul 30, 2010 | 04:13 AM
peterz's Avatar
Default Bleeding air from brake lines - advice ??
98 S70. fixed leak, now need to bleed air from lines.....how can I tell when I have all the air out? does this require pumping the brakes as filling is done ?
Old Jul 30, 2010 | 05:59 AM
cb1313's Avatar
Default Bleeding
First.. are you rying to bleed alone or do you have someone who can pump the brake ?
Cb
Old Jul 30, 2010 | 10:35 PM
gdog's Avatar
I don't care if you have a helper or not; the only way to bleed brakes on modern cars with ABS is with a pressure bleeder! Then it's a one person job too.
Motive is one supplier.
Old Aug 2, 2010 | 07:28 PM
mouserace2010's Avatar
All you need is a pressure bleeder
rolling2
Oct 20, 2010 01:08 AM
snpklinefelter
Dec 22, 2009 06:26 AM
sasp11
May 20, 2009 08:40 PM
act1292
Nov 21, 2007 08:41 AM
Psaboic
Jun 1, 2006 01:14 AM
