Brake and ABS light stays on 30 seconds
Old Jul 19, 2009 | 09:03 AM
99S70GLT's Avatar
Default Brake and ABS light stays on 30 seconds
This cycle has happened several times. Car is started and dash brake light and dash ABS light comes on, stays on for 10 to 30 seconds and then goes off.
Brakes seems to work fine. Cruise quits during this "light on" but since the cruise is linked to the brakes, that makes sense.
The dealer recently installed a new TCM and the positive cable from the battery to the main fuse box.
Any body got any ideas? Thanks in advance for you help.
Old Jul 19, 2009 | 09:04 AM
99S70GLT's Avatar
forgot one thing. this does not happen often. just every week or two.
Old Jul 19, 2009 | 10:27 AM
ABS module bad?
Old Jul 19, 2009 | 10:34 PM
99S70GLT's Avatar
is this something I can test myself? will this show a code on an OBDII tester?
Old Jul 20, 2009 | 06:53 PM
If it can read ABS codes yes you can pretty much tell by that.
There is specific codes that stay in there when it is bad.
dlaxdal
Apr 21, 2012 09:54 PM
Rosy
Sep 24, 2010 01:32 AM
Rosew6211
Feb 6, 2010 01:08 PM
tarheel00
Aug 18, 2007 09:05 AM
jcmartin
Apr 26, 2006 09:31 PM
