cam shaft seal
Old Oct 23, 2010 | 10:37 AM
James Ira's Avatar
Default cam shaft seal
I am leaking a lot of oil.. I took off the hose connecting to the turbo and oil is in the turbo.... I have an idling issue and I put a post up and someone said it could be my cam shaft seal leaking into my distributor..... now it looks like the leak is coming from right in front of the turbo but can't see exactly where.... I am assuming the front cam shaft seal is the one more towards the front of the the car... now does this sound like a front or rear seal leaking?
Old Oct 23, 2010 | 09:33 PM
Volvolcano's Avatar
What year and model car?
Old Nov 25, 2010 | 02:04 PM
volvoQ's's Avatar
I just replaced the camshaft seal in my 1990 740 turbo. Wasn't a big deal. Yes, it was in the front of engine. Not sure how similar your engine is to mine, but you may be able to remove timing belt cover and see if it is leaking there.
Old Nov 25, 2010 | 11:54 PM
I assume you have a S70 since you have posted in this area. When people refer to the front they mean the end of the motor that has the timimg belt. When they say aft, the mean the end on the drivers side, closest to the turbo & distributor. Yes there are two seals on each end.
The important thing is to make sure you deal with the cause. Internal pressure inside the motor can cause seals to leak. Make sure the PCV system isn't plugged.
s60propshaft
Jan 15, 2023 06:59 PM
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
Volvo-Profess
Jan 14, 2011 05:55 PM
cool_kyle_3000
Mar 6, 2008 11:48 AM
floryed
Apr 9, 2005 11:58 AM
