camshaft removal and alignment?
I have a s70 with the 234t engine. pulled the cam cover and inspected, replaced the cam seals and put the cams back in. I removed the cam gears and when i put the cams in i put them in where i thought they should be where the lobes werent pushing on the valves.
How do i know exactly that i installed them correctly if the cam pulleys line up somewhat to where they should be? There isnt a keyway on the cams so the cam gears can pretty much go anywhere. two bolts are up on the intake cam, and one up on the exhaust. that is what the chiltons i have has listed in the pics but since its a triangular bolt pattern i could put it in one of three ways.
Do i have to remove the cams again? The crank is aligned on the timing mark. i believe this engine is interference, but will i have a problem rotating the cam without taking it out?
If you did not have them lined up properly and put the cam cover on you might have bent valves already.
There is a cam tool you cam make to line the cams up properly. Then install the pulleys.
Use the method in the link to make the tool.
https://volvoforums.com/forum/general-volvo-chat-5/cam-locking-tool-fabrication-38396/
pierremcalpine
Canada, Over Seas & Elsewhere
04-25-2014 03:17 PM
awfulwaffle
11-09-2013 11:57 AM
4n6pi
03-08-2013 10:53 AM
junkprospector
09-06-2011 09:26 AM
