Cant get the steering wheel/ airbag off??
Old Sep 6, 2010 | 07:13 PM
xxblindxx's Avatar
Default Cant get the steering wheel/ airbag off??
Trying to remove the dash and ive read the instructions on how but i cant figure out how to remove the steering wheel/airbag..
i took the cover off behind the steering wheel and i removed the turn signal and the wipers arm..
i know there are the 2 bolts, one on the left and one of the right side of the whell, on the back side...
i'm having a hard time getting into the holes and removing the screws... after i remove those 2 screws should the whole wheel come off or just the horn/airbag???
kinda stuck, please someone help
Old Sep 6, 2010 | 07:22 PM
Did you remove the 2 T-30 screws in the holes?
After that the airbag comes off then there is a 18MM bolt holding the steering wheel on.
But be sure to lock the SRS contact reel before removing the wheel.
Old Sep 6, 2010 | 08:10 PM
xxblindxx's Avatar
Im going to go back out and try to remove the 2 t-30's ..
what do you mean by locking the SRS contact reel, sorry :x
Old Sep 6, 2010 | 08:26 PM
xxblindxx's Avatar
k well the t-30 seems too big?
i got the t-25 in there and it seems that the bolt was turning but nothing was really happening, does the bold come all the way out and when it does, does the "horn cover" come off?
err sorry just this step has been taking forever! :/
Old Sep 6, 2010 | 09:32 PM
It is a T-30.
The bolt unscrews and stays in the steering wheel.
Then the center part will just pull off then you unplug it.
Then to lock the contact reel put the steering wheel straight.
Then to the bottom left side you will see a screw sometimes the yellow strap goes to the screw. Then above the 18MM screw you will see a hole. With the wheel straight through that hole you will see in the white part behind the hole is a groove. Put the screw through the hole and into the groove and that will lock it in place.
Also after the screw is removed it is a good idea to use a marker and make a line from the steering wheel to the center shaft to mark the wheel for putting it back on.
Old Sep 6, 2010 | 09:44 PM
xxblindxx's Avatar
Okay i got it off! thanks for your help but i think i screwed up bad =x
when i was messing with the wheel i unplugged the orange clip behind the wheel and plugged it back in because i realized it did not need to be unplugged..
i turned my car on and the SRS light was on and every 10 seconds or so it sounded as a pump was kicking on under the dash, what is that related to? =x
how back did i **** up..
again, thanks for your help!!!!!
Old Sep 6, 2010 | 09:53 PM
Once all done get someone to clear the SRS codes. Not sure about the noise though.
Old Sep 6, 2010 | 09:59 PM
xxblindxx's Avatar
well i'm going to finish up tomorrow and if its still making the noise ill try and figure it out.. =/
thanks!!
Old Sep 7, 2010 | 01:42 PM
xxblindxx's Avatar
Well i have the dash all loose and ready to come out (i think) haha
but just wondering, any special types of screws i should use and length for mounting the metal strip?
thanks!
Old Sep 7, 2010 | 08:08 PM
I use really small ones and predrill the holes first.
Old Sep 7, 2010 | 09:24 PM
xxblindxx's Avatar
k i got that done, thanks!!
how does this one look? seems sturdy..
But what would i go about doing on something like this one =x
there is just a big hole haha
the little pics wont really fit in there, something i can do to help it?
Old Sep 7, 2010 | 09:28 PM
Try to crazy glue the piece back in there for a start. Then add the metal after the glue drys.
Old Sep 7, 2010 | 11:34 PM
gdog's Avatar
would recommend JB Weld over crazy glue...
but yeah, then reinforce it w/sheet metal and small screws or rivets.
Old Sep 8, 2010 | 01:41 AM
xxblindxx's Avatar
using gorilla glue seems to be working good!
but the only thing that sucks about that last one is that there is not really much to glue it to, the hole is bigger than the piece (missing pieces of plastic) so im going to try and glue it the best that i can and hope it works =/
we will see haha
Old Sep 8, 2010 | 07:33 PM
xxblindxx's Avatar
ERRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
i got the dash back in and i got every screw in the fire wall besides the far drivers side!!!! i can put a close hanger through it but the screw wont go in!!
this is frustrating.
Old Sep 8, 2010 | 08:44 PM
Worse case drill the under the hood side of the hole a little bigger. That will allow the screw to go on a little angle if needed. If you look closely in the hole the center part is pretty big.
Old Sep 8, 2010 | 09:25 PM
  #17
xxblindxx's Avatar
Well i just removed the dash and saw that the hole moved, so it took like an extra 5 mins to realign it and put it back in...
i have about everything in now and i started my car, the "arrow" is now flashing and the SRS light it is, you said to clear the SRS light, can that be read and done with an OBD scanner or does that only check the "check engine light"
also, for the flashing "arrow" could that be related to my shifter, i think when i was putting the dash in i broke something, although i did put the car in all gears and it seems to be moving through the gears fine..
thanks for all the reply's!!!!!!!!
Old Sep 8, 2010 | 09:30 PM
  #18
If you had something still unplugged in either the SRS or with the shifter that would set codes. That would keep the SRS light on and make the arrow flash.
Old Sep 8, 2010 | 09:57 PM
  #19
xxblindxx's Avatar
well i'm sure i did have stuff unplugged =x lol
its kinda dark so i'm going to have to figure it all out in the morning but the "shiftlock override" is broken i think..
i'm going to clean the codes and then ill post back
Old Sep 8, 2010 | 10:00 PM
  #20
You might not be able to clear all of them. Most generic scanners only read Engine codes.
What did you break on the shiftlock?
