Cant get the steering wheel/ airbag off??
Old Sep 9, 2010 | 08:24 PM
  #21
xxblindxx's Avatar
so everything is working now, dash feels amazing!! no more noise!!
only thing is that the SRS light is still on, how would i go about getting that cleared?
thanks!!
Old Sep 9, 2010 | 08:31 PM
  #22
You need to find someone or a shop that can read and clear the codes.
Congrats on the good job!
Old Sep 9, 2010 | 08:46 PM
  #23
xxblindxx's Avatar
Thanks for the day to day help! and the write up you made!
doubt i would have been able to finish it haha or would have just taken a week longer.
Old Sep 9, 2010 | 08:59 PM
  #24
Your welcome!
Old Feb 8, 2012 | 02:15 PM
  #25
LamboSE5's Avatar
Default Just about to succeed...
Originally Posted by tech
It is a T-30.
The bolt unscrews and stays in the steering wheel.
Then the center part will just pull off then you unplug it.
Then to lock the contact reel put the steering wheel straight.
Then to the bottom left side you will see a screw sometimes the yellow strap goes to the screw. Then above the 18MM screw you will see a hole. With the wheel straight through that hole you will see in the white part behind the hole is a groove. Put the screw through the hole and into the groove and that will lock it in place.
Also after the screw is removed it is a good idea to use a marker and make a line from the steering wheel to the center shaft to mark the wheel for putting it back on.
I have the small screw in place through the hole at the top right above the 18 MM Bolt. But now that that's "pinned" there, I can't remove the steering wheel - UNLESS - I unplug the green connector on the back of the horn/airbag part of the wheel.
Is that what I'm supposed to do now? Unplug the green connector after it's pinned to the ... hole?
(Are we just pinning that orange cable to the 'steering column', and it says behind without the wheel when you remove the wheel?)
PS: by this: "Also after the screw is removed it is a good idea to use a marker and make a line from the steering wheel to the center shaft to mark the wheel for putting it back on"
-do you mean, mark under the 18mm bolt where the outer part of the spline would line up/meet the inner spline? So you put it back in the 'exact' same place/rotation later?
Thanks for any help tech.
Old Feb 13, 2012 | 10:24 PM
  #26
xxblindxx's Avatar
Been awhile since i took it off but you should make the wheel where it connects, its going to be * (star) looking. so just make the rivets up so when your put the wheel back on it slides in the same position it was in before
hope that helps any..
Old Feb 13, 2012 | 11:17 PM
  #27
Yes you have to unplug the air bag. The screw will hold the contact reel from spinning.
Yes mark under the 18MM screw.
boarders123
Jun 23, 2012 09:16 PM
35mm
Jun 7, 2012 01:53 AM
ded137t5r
Oct 30, 2011 09:46 AM
doddj22
May 8, 2009 09:38 PM
defuse
Jul 18, 2005 10:34 PM
