CAR STUTTER IN THE MORNING
Old Dec 26, 2008 | 05:16 PM
chachouu's Avatar
Banned
Default CAR STUTTER IN THE MORNING
The car was running great last night,I was even doing 120MPH on my way home,this morning I start her up,and I was like what the hell,I put premium GAS and a bottle of Chevron still nothing, it still stutter and shake when idling after a cold start.
any advice
Old Dec 26, 2008 | 05:48 PM
Default RE: CAR STUTTER IN THE MORNING
Check engine light on?
Old Dec 26, 2008 | 05:58 PM
chachouu's Avatar
Banned
IT was on last week after I reset it,it still hasn,t come back on.
Old Dec 26, 2008 | 06:08 PM
What was the code?
Old Dec 26, 2008 | 06:22 PM
chachouu's Avatar
Banned
that it was running lean,possible air leak,which you advise me to spray with carb cleaner to see if the idle changed.
i did that there was no change in idling.
Old Dec 26, 2008 | 09:51 PM
Maybe Mass Flow is going bad.
Old Dec 27, 2008 | 07:53 AM
FredMc's Avatar
It's probably a vacuum hose since there are a gagillion of them on the car. Look near the throttle body tree, and around the air box.
Even if they are attached they can be rotted and leaking.
Also clearing the code is not the same as fixing the code problem. If you clear the code, it sometimes takes 120 miles until the car decides it needs to fire the code again.
What is the code number? Then do a search on it and see what the usual problem with this car and code is. Normally that will solve it.
S40Fix
Jan 24, 2012 05:12 AM
gkinser
Nov 26, 2008 09:41 PM
leland
Nov 18, 2008 11:04 PM
volvolove
May 20, 2007 07:07 PM
amgqmp1
Dec 4, 2003 12:30 PM
