Change plugs - how to remove turbo pipe?
Old Apr 15, 2009 | 12:53 PM
bw77's Avatar
Default Change plugs - how to remove turbo pipe?
I want to change the spark plugs on my 99 S70GLT. Looks like I need to remove the turbo pipe that runs over the top of the engine in order to remove the plug cover. What's the best way to do this? Thanks.
Old Apr 15, 2009 | 04:21 PM
FredMc's Avatar
you don't have to remove it. You can work around it, not hard.
Old Apr 15, 2009 | 06:29 PM
Johnny Mullet's Avatar
That cover will sneak out from under the tube. I suggest you use Volvo plugs.
Old Apr 15, 2009 | 07:35 PM
S70driver's Avatar
If you want to remove it, just unscrew the two hose clamps holding it in place on the rear and front turbo hoses that attach to it. Then unscrew the small brace that holds it in place as well. It looks like a strap going around it.
Newport_j
Sep 15, 2014 12:23 AM
vldu2
May 24, 2008 08:15 PM
ludeless
Dec 12, 2007 05:29 PM
folharth
Oct 3, 2007 09:08 AM
yellow95
Apr 22, 2006 12:42 AM
