Changing barkes on 2000 s70
Old Aug 30, 2008 | 09:14 PM
Maynard's Avatar
Default Changing barkes on 2000 s70
Ok, I'm extremely challenged, so type slow. I'm in the process of changing the brake pads on the front end. I have removed two bolts, and two pens (via 7mm Hex socket). However, the caliper will not come off. What have I overlookied?
I appreciate the feedback guys.
Dave
Old Aug 30, 2008 | 09:42 PM
Default RE: Changing barkes on 2000 s70
Did you remove the spring on the outer part of the caliper?
Old Aug 30, 2008 | 10:11 PM
Maynard's Avatar
Thanks for the quick response Tech. I did not remove a spring. Where is it located exactly? Is it on the bottom or something?
Old Aug 30, 2008 | 10:29 PM
looking straight in at the caliper from by where the wheel goes it in the end of the caliper by the backside of the wheel.
Old Aug 30, 2008 | 10:35 PM
Maynard's Avatar
Thanks Tech. I will complete the job tomorrow. Hopefully everything will work out fine.
This is a great sight with lots of top notch info. Keep up the good work.
Thank you,
Dave
Old Aug 30, 2008 | 10:41 PM
Your welcome also use a screw driver between the pad and rotor easy to push the pad back some to make the caliper slide off easy. The pads can also make it hard to slide off. So if you push the piston back some it will slide right off.
Old Sep 1, 2008 | 03:20 PM
Maynard's Avatar
Wow, that was easy. Once you figure out how to, it's a quick job. I took out the two bolts on the caliper, which I did not need to do. The clip was easy to remove and put back on.
You were right about the pads being shoved tight to the rotor. By applying slight and constant pressure to the brake pad with a screw driver, it eased the pressure and slid right off.
Thanks again Tech, you simplified this for a mechanically challenged and current grease monkey
Old Sep 1, 2008 | 07:38 PM
Glad you got it all done!!
rainman14624
Oct 4, 2010 11:49 AM
ZiggyS70
Mar 10, 2010 10:07 AM
aruizdelhoyo
Jan 22, 2009 04:46 PM
Frank88
Jan 17, 2005 12:14 PM
timbo
Oct 27, 2004 09:27 PM
