Check Engine Light
Old Sep 20, 2007 | 05:47 PM
Ted1's Avatar
Default Check Engine Light
Hi,
I just had engine replaced with used engine with 38M K, on my 199 S70 AWD.
Check engine light is on with code reading rear O2 sensor.
It seems strange as this was not the case before.
Installer (Volvo/Audi Specialist) is very good, chcked to with Ohmeter or something
to make sure no wires were broken, chcked out ok.
Will this go away as the engine is not running rich as before, or
is it a coincidence, and the O2 Sensor just happened to go at this particular moment.
Any suggestions apreciated.
Thanks in advance.
Ted
Old Sep 21, 2007 | 11:54 AM
JPN's Avatar
JPN
Default RE: Check Engine Light
Hi Ted,
The O2 sensors on Volvos & European cars are notorious for premature failure (Bosch). Also, even if they are fine, they can trigger CEL for very trivial reasons, such as neglected tune-up that is causing less-than-perfect combustion.
I would go over the ignition components (plugs, plug wires, distributor cap & rotor, dump a large bottle of Techron fuel system cleaner into the fuel tank, check/replace air filter, fuel filter, etc...). Also, make sure that the EGR &PCV systems are in good working order, and clean the throttle body if you can.
I hope this gets you started.
Cheers,
JPN
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
