Code p0108
Old Mar 8, 2009 | 05:30 PM
cjbmustang's Avatar
Default Code p0108
I got a check engine light and read the code and it was p0108
MAP/Baro High circuit voltage
I bought a new map sensor figuring the problem would be resolved...nope! I cleared the code and it's still there. Am I missing something? There is an o-ring attached at the bottom of it. I took off the old one and there was no vacuum line attached, just the connector from the harness.
The car drives and idles fine. What else should I be looking for?
Old Mar 8, 2009 | 06:02 PM
cjbmustang's Avatar
oddly enough, i blew in the old sensor and plugged it back in and it worked...i will update later tonight
Old Mar 8, 2009 | 07:29 PM
Hopefully all is well.
Old Mar 8, 2009 | 11:05 PM
cjbmustang's Avatar
Well, I did about 30 miles of driving and no check engine light. I have a feeling I haven't heard the last of p0108... dun dun dun....
Is it common for new MAP sensors to be DOA?
Old Mar 9, 2009 | 06:39 PM
Not real common but always possible.
Old Mar 9, 2009 | 07:18 PM
FredMc's Avatar
I had an issue with this recently. I put a new one in August 08 after a code. It was fine until January 09. I cleared the code myself, and it came back on after 150 miles. I learned that it takes about that long for the code to repeat itself. I took it back to the place I got it in, and they replaced it. They did some other checking and couldn't find why it came on.
After that I have been code clean again and have put over 1000 miles on it.
Yes, they can go bad. And I think after 150 miles you may be home free.
The car won't run any differently either way.
Old Jun 18, 2009 | 03:56 PM
Dozer520's Avatar
where is it? what does it look like?
Old Feb 11, 2013 | 08:11 PM
ABVO850's Avatar
I got a p0108 map sensor high intake CEL code today. I installed a Eurosport Intake two weeks ago.. thinking this is where the code is stemming from. Anyone have any idea how to keep this code from coming back with the high flow intake installed?
jpirish
Jul 15, 2010 02:38 PM
volvorecycle
Aug 1, 2009 03:10 PM
lordhowe
Sep 26, 2007 03:34 PM
TBoone
Aug 8, 2006 12:52 AM
hordezla
Apr 27, 2006 09:40 PM
