code p0410 popping up
Old Feb 11, 2008 | 07:31 PM
Fixityourselfer's Avatar
Default code p0410 popping up
I've got a 98 s70t5 115k. check engine light has come on. autozone read codes for me and it's p0410. what is the procedure to properly check the system and diagnose? Thanks
Old Feb 11, 2008 | 08:39 PM
Default RE: code p0410 popping up
Either the air pump or valve is bad.
Do you hear like a hair dryer noise in the morning after first starting the car?
Old Feb 12, 2008 | 06:56 PM
Today in the morning I listened . . . .absolutely no such sound inside the cabin or under the hood either. What's next?
Old Feb 12, 2008 | 07:19 PM
Air pump is bad.
Old Feb 12, 2008 | 07:35 PM
Do I need a new one($$$) or is there a way to save(fix) the one i've got? 2. where can I get a guide how to do the job(properly the first time) my chilton & haynes manuals don't cover it . . .Thanks
Old Feb 12, 2008 | 07:59 PM
You will have to buy a new one.
Find the sensor it sticks out the front of the booster between the booster and the engine.
Look on the booster there is a metal ring that locks it in. Use a hook tool to pull the ring and release the sensor.
But first pump the brake pedal till it gets hard.
Old Feb 13, 2008 | 09:51 PM
I've just heard from a friendthatthe air pump on his 98 s70 went bad too,he replaced it, and the replacement went bad as well, a short while later.
Can it be that this trouble we're having with the air pumps is being caused by something else? Combination valve perhaps?
( I'ts just that I'd like to be 100%sure everything else is o.k. before I put in such an expensive piece $350-$450) Thanks
Old Feb 14, 2008 | 05:20 PM
simul8guy's Avatar
Never replace the air pump without changing the bad check valve that caused the pump to fail or the new pump will also fail. Check out this thread from Swedespeed.
http://forums.swedespeed.com/zerothread?id=89794
Old Jan 4, 2016 | 01:35 PM
mmpd's Avatar
I have a 98 V70R and have this code. Check engine light came on after a long sit under some snow. I have the hairdryer sound when I start the car - does that mean this is a valve issue?
Old Jan 4, 2016 | 08:31 PM
You can start chasing it or just bypass it.
Old Jan 4, 2016 | 08:57 PM
Psaboic's Avatar
Look for RSPI's video on how to bypass it. Works like a charm and solved all my issues with the P0410.
rob960
Sep 7, 2011 08:28 PM
Z06john
May 7, 2009 04:39 PM
92Typhoon
Apr 25, 2008 06:59 PM
safari
Dec 10, 2007 07:46 PM
BrianB1975
Jul 13, 2006 01:07 AM
