Fault code P0410....what's that mean...
Old Dec 3, 2007 | 04:37 AM
safari's Avatar
Default Fault code P0410....what's that mean...
Hello folks......
I'm new to this group and very happy with my new to me S70 1998 2.4L non turbomanuel and red in color.
The only problem for the moment is a fault code that appear yesterday P0410.
My scan tool reveal 'Secondary air injection system malfunction' any toughts...
I know i can go to dealer to have it fixed but as many of us i like to work on my car and i would really like to have an idea of what is the 'secondary air system'
Thanks in advance
Robert
Thanks in advance
Old Dec 3, 2007 | 08:19 AM
Eric J's Avatar
Default RE: Fault code P0410....what's that mean...
I think this will help.
P0410 Secondary Air Injection System
"Secondary Air" is an abbreviated term for the "Secondary Air Injection System". This system uses a separate air pump and a series of metal and rubber tubes to force outside air into the exhaust stream and help the catalytic converter burn away excessive emissions.
Possible causes and fixes are:
[*]Poor connection, rubbed-through wire insulation or a broken wire inside the insulation.[*]Inspect harness connectors for backed-out terminals, improper mating, broken locks, improperly formed or damaged terminals, poor terminal-to-wire connection, and damaged harness.[*]Check for worn or loose AIR pump drive belt.[*]Check for pinched, kinked or restricted AIR pipes, hoses or fittings.
Problems with this system can stem from electrical circuits, solenoids, or switches that control the pump and valves. Other problems include sticking valves, loose, rusted, or poorly connected lines, a broken drive belt, or possibly a bad pump.
Old Dec 3, 2007 | 09:52 AM
safari's Avatar
Thanks Eric.....
I think i found them problem or a part of the problem.....i found a purple smallair hose that goes from behind the engine connected to a round metal bowl looking like a little air filter box to i don't know where......the hose was simply disconnected and i had a look to find where it could be plug to but i did not find nothing.The small hoses goes from like i said behind the engine to the front of the engine....please if you know tell me were.....
Thanks in advance
Robert
Old Dec 3, 2007 | 12:22 PM
Eric J's Avatar
Post:Please tell me where
"OK folks...
I finally found where to pluged the vacuum hose
Thanks"
Looks like you discovered the location, Let us know if it gets rid of the PO 410. It might take some driving to clear it.
Old Dec 3, 2007 | 10:19 PM
samadkins29's Avatar
Doesnt that purple hose go to the CBV? which would be part of the turbo system and not the air pump system?
Old Dec 5, 2007 | 05:47 PM
ORIGINAL: samadkins29
The hard purple hose with the rubber on each end goes to the air pump.
Old Dec 10, 2007 | 07:46 PM
dkbmx8485's Avatar
Maybe you can use the diagram on the left to get a visual.
http://www.eeuroparts.com/searchresu...2&cat=1052
rob960
Sep 7, 2011 08:28 PM
healthnt
Jul 6, 2010 12:07 PM
Z06john
May 7, 2009 04:39 PM
BrianB1975
Jul 13, 2006 01:07 AM
jrw
Nov 19, 2005 09:13 PM
