CV BOOT SPLIT
Old Apr 24, 2007 | 01:57 PM
rmclemns's Avatar
Default CV BOOT SPLIT
I have a 1998 Volvo S70 that has a split CV boot on the drivers side, outer boot (one closest to the wheel). I have a Haynes manual, but it is unclear as to whether I have to tear the whole suspension apart just to replace the boot. Can the boot be replaced on the car and if so, what is the procedure? What things do I need to be careful about while performing this task? Thanks.............Mike
Old Apr 24, 2007 | 09:47 PM
Default RE: CV BOOT SPLIT
Remove the axle from the car is the easiest way to do it.
Better yet you should be able to find a rebuilt axle pretty cheap just replace the axle.
Usually when the grease all comes out the joint is bad.
kevin_r
Jul 21, 2013 11:28 AM
poorfatjames
Aug 24, 2010 06:42 PM
bob123422
Nov 30, 2006 12:56 AM
jktiffin
Oct 11, 2006 04:10 PM
jcmartin
Jun 25, 2005 11:49 AM
