Damn front-end vibration!
Old Dec 9, 2008 | 11:07 AM
RPMCanes's Avatar
Default Damn front-end vibration!
OK, I've had both front struts, tires and CV joints replaced, and I have also had all motor mounts certified. I'm still getting a vibration in the front end, more so able to feel in the body than in the wheels. Any suggestions?
Old Dec 9, 2008 | 11:25 AM
Default RE: Damn front-end vibration!
All 4 rims and tires in good condition?
Old Dec 9, 2008 | 11:51 AM
RPMCanes's Avatar
Tires have a slight chop on the outside edge, but are relatively new. Not sure about the rims. I think it shakes too much for just the rims to be causing it.
Old Dec 9, 2008 | 04:11 PM
You might have a tire with a broken belt.
Old Dec 10, 2008 | 06:58 AM
RPMCanes's Avatar
I seem to notice it the most when I accelerate. Those tires are less than a year old. I started having issues when I let F'n Kauffman scam me into replacing the front struts with P.O.S. Monroe Sensatracs! Arrgh!
Old Dec 10, 2008 | 07:41 AM
What brand was the axles?
Old Dec 10, 2008 | 07:49 AM
RPMCanes's Avatar
I think one was a new Moog, and the other was a rebuilt.
Old Dec 10, 2008 | 08:11 AM
I wonder if even though they are new and rebuilt if the inner joint on one is bad.
It is pretty easy to check. With the car in the air grab the total inner joint at the transmission and hold onto it. Then kind of rock the wheel foward and back with the other hand feeling for play in the inner joint. There should be none at all.
Old Dec 10, 2008 | 08:32 AM
RPMCanes's Avatar
My mechanic thinks it might be the struts, since they are so firm they transmit every single road impurity into the wheel. I'm sure they are a contributing factor, and if I and an extra $500 lying around I'd take them out, but that seems like an unlikely cause for that kind of vibration.
Old Dec 10, 2008 | 08:47 AM
I would check the axles. Most rebuilds do not include new parts in the inner joints. Unless it changed there was no parts anyone could buy to rebuild the inner joints.
Old Dec 12, 2008 | 02:06 PM
RPMCanes's Avatar
OK, so my shop checked it out and physically verified all joints on the outside, and there is no play anywhere in the front end. I think at this point could it be something in the transmission or the rack unit that is causing it? This is so incredibly frustrating!!
Old Dec 12, 2008 | 04:35 PM
Possibly but something sounds fishy.
Old Dec 13, 2008 | 09:25 AM
RPMCanes's Avatar
OK, so I had another Volvo shop check it out, and they think it could be the motor mounts.There is a bushing on the driver's side below the edge of the transmission, and there should be about a half-inch of clearance in between the bushing and the transmission. My transmission is almost sitting on top of it, which means the motor mounts have collapsed too much. That would throw everything out of alignment. Does that sound right?
Old Dec 13, 2008 | 09:43 AM
Yes it does. I went through similiar not long ago.
Old Dec 30, 2008 | 03:07 PM
RPMCanes's Avatar
Can they be done one at a time? I figure the front one would have the most impact.
Old Dec 30, 2008 | 03:53 PM
Yes as long as you don't a wait really long time to replace the rest.
Old Jan 8, 2009 | 11:41 AM
  #17
RPMCanes's Avatar
OK, so if the front and rear hydraulic motor mounts are replaced, is that going to hasten the failure of the mount that's on the pass. side underneath the crank pulley? That one checks out OK at the moment.
Old Jan 8, 2009 | 04:49 PM
  #18
If you replace the other 2 then the R/S one will have pressure taken off of it.
Old Jan 11, 2009 | 08:42 PM
  #19
crunch5868's Avatar
its probably not the issue in this case but after i go drifting in my car the car will shake side to side and come from the front end when i drive above like 30 for a couple days. It was from ice building up in parts in the wheel well
Old Jan 27, 2009 | 08:09 AM
  #20
RPMCanes's Avatar
OK, so the front, rear, and bottom side mounts have been replaced. Some improvement, but I think the root issue is still there. I'm curious as to what Tech told me about rebuilt CV joints not having new inner axles. I think that may be what I'm experiencing. That right side axle was replaced with a rebuilt one in October so hopefully if I can have (now a third) independent Volvo shop verify that they will replace it with a new one. Is there a huge price difference between rebuilt and new axles?
