dash removal vs other jobs on this thing?
Old Mar 22, 2013 | 09:31 AM
gentlejax2's Avatar
Default dash removal vs other jobs on this thing?
I need to remove the dash in my 99 s70 t5 so I can put the dash I got at the junkyard in.
now it was a pain but not really bad to remove .
How does changing out the PVC system rate compared to the dash job?
also if I make it that far in the repair department, should I change the oil cooler lines then since they a prone to leak and car has 170K on it ?
I am not that experienced with this car. I have delayed all this for months
Old Mar 22, 2013 | 10:19 AM
PCV is a 4 where as the dash is a 3. To me it's all about the instructions you have to work with and tools you'll need. It will take 4 to 5 hours the first time. If it needs to be done you need to do it ASAP.
The oil cooler lines are not near the PCV system.
Old Mar 22, 2013 | 10:30 AM
gentlejax2's Avatar
ok well I am just trying to do it all while I have the time and motor is somewhat open.
I havnt actually seen where the oil cooler lines run. I have looked at removal posts.
the dash was actually not bad getting it out. just time.
I got an exhaust leak too now right where the turbo meets the exhaust pipe flange.
Old Mar 22, 2013 | 10:45 AM
Old cars will always have something needing to be done to them to keep them in good running condition. Beats the heck out of car payments.
Also, having a good hobby will help keep us out of trouble.
x-angel
Jan 12, 2013 08:34 PM
tobolate
Nov 26, 2009 11:10 AM
ceeNweej
Apr 29, 2008 02:43 PM
tr_car_nut
Jan 19, 2008 09:37 AM
