engine staggers, faulty ECU ?
Old Jan 14, 2009 | 12:05 PM
vike's Avatar
Default engine staggers, faulty ECU ?
Hello everyone. My family has been proud Volvo owners ever since my first ownership back in 1980 of a 74 164E, a car ahead of it's time. I wore it out. My wife owns a 98 S70 that has 135K miles and until last week had run great. It cut off on her one afternoon home from work and then "coughed" on the restart failing to start. She waited 10 minutes, reatarted ... engine coughed then the RPM ran to 5K before it idled back and started coughing. It took three attempts for her to get it home.
I discovered that the plugs, wires, cap and rotor were all original so I replaced everything with OEM spec items, also the plugs. On restart ... the same problem. All fuses checked out OK. I pulled the newly installed plugs and found black fowling and I could smell raw gas. I also noticed that when the ignition was initally turned on, I did not hear the fuel pump powering up before turning further to crank the engine. Starter and battery are fine.
Culprits? Could it be a bad fuel pump/fuel filter? Perhaps a faulty ECU?
Old Jan 14, 2009 | 12:11 PM
Default RE: engine staggers, faulty ECU ?
I would check the mass flow sensor.
If you have an OBDII scanner pull the plug for the mass flow and see if it will start and idle normal.
It will set codes in the ECU though.
Old Jan 14, 2009 | 12:21 PM
vike's Avatar
THANKS ...
I indeed have an OBDII code reader, I checked the computer and zeroed it out before atttempting the restart and it does not show any faults now. I do not have a "repair manual" so I have no idea where the mass air flow sensor is. I plan to work on it some more this afternoon and will try to find the MAF. Her old 240 had a MAF problem and when we replaced it, problem solved.
Old Jan 14, 2009 | 12:32 PM
The Mass Flow is mounted to the air box on the S70.
Old Jan 14, 2009 | 09:35 PM
vike's Avatar
THANKS !!!
Looks like problem solved. I unhooked the MAF sensor and the car started up. It struggled a bit but ran consistently. Heading to the Volvo shop for a new MAF sensor, $235.
Old Jan 15, 2009 | 06:52 AM
chachouu's Avatar
Banned
why buy one at the dealer,look around Ebay,you,ll pay a lot less.
makaveli2k
Aug 8, 2012 12:32 PM
Jayrivera
Nov 9, 2011 08:54 PM
91shelby
Jun 20, 2011 06:56 PM
PHIL_V70_GLT
Feb 22, 2009 09:49 PM
bigern45
Aug 5, 2008 08:14 AM
