FLUID LEAK, DRIVERS FRONT WHEELWELL
Old Dec 11, 2006 | 02:08 PM
rmclemns's Avatar
Default FLUID LEAK, DRIVERS FRONT WHEELWELL
While checking the brakes on my 1998 S70 I noticed what appeared to be fluid around the
outside of the wheelwell. Further investigation revealed that it was very black and almost like
oil in texture and it appeared to be coming from the outer drive shaft boot next to the wheel,
and was being flung out to the wheel well cover. There was even this black oil on the lower part
of the strut, that comes down from the fender mount. I checked the boot and could find no tears
or rips. It is not brake fluid and I checked the brake lines just to be sure. Anybody got any ideas
what this fluid is and where it might be coming from??
Old Dec 11, 2006 | 03:56 PM
elbert's Avatar
Default RE: FLUID LEAK, DRIVERS FRONT WHEELWELL
Check the clamps to the cv boots. If the oil is thick and gooey, it is most likely your cv grease.
Old Dec 11, 2006 | 09:17 PM
You could have a very small pin hole and the Grease will come out.
zcihak
Jul 29, 2011 08:21 PM
kastelein
Apr 28, 2011 12:06 AM
ceccii
Aug 19, 2009 12:16 AM
vetalbig
Oct 22, 2008 07:34 AM
kartman01
Nov 26, 2005 09:47 AM
