Flush Transmission?
Old Nov 2, 2011 | 05:22 PM
twoarcadians-volvo's Avatar
Default Flush Transmission?
I have a '99 S70. During oil change, mechanic said transmission fluid is a little brown and recommended a fluid change/flush. Called Volvo dealer mechanic who stated a flush could cause particles to float and destroy tranny. Best not to change fluid. But burnt fluid could destroy tranny as well. Any suggestions?
Old Nov 2, 2011 | 07:03 PM
quietlymknnoise's Avatar
Check out the IPD instructions for changing not flushing the ATF.
Old Nov 2, 2011 | 08:11 PM
tony1963's Avatar
Changing the fluid will not hurt the transmission unless you use the wrong fluid. In fact, if the fluid was changed every 30-40k miles, they would last longer.
Old Nov 3, 2011 | 03:39 PM
That's the problem with these trannies, the freeking dealer recommending that you do NOT service the thing.
Read this: https://volvoforums.com/forum/volvo-...57/#post268122
And this entire thread: https://volvoforums.com/forum/volvo-...tep-step-5157/
I suggest you drain and refill it 3 times.
Old Nov 12, 2011 | 10:16 PM
jbuck's Avatar
Default Transmission flush
Of course don't flush the tranny how is the dealer every going to make any money replacing your transmission when it breaks. Dealers!! not saying that all dealers are bad but i don't care how good the lubricant is over time and use it will break down and get contaminated. Its just good insurance. Read the IPD instruction as instructed and follow to the letter.
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
shop2
Nov 1, 2011 08:56 AM
Glenn B
Feb 19, 2008 04:57 PM
94volvo850
Feb 18, 2005 06:49 PM
Evren
Dec 21, 2004 09:20 PM
