Fog Light Kit Needed (part numbers)
Old Jun 10, 2013 | 09:41 PM
GTO 06's Avatar
Default Fog Light Kit Needed (part numbers)
I have been trying to find this information about installing fog lights and the parts needed.
I have searched many of the post and can't find what is needed
What I would like is a list of the parts and part numbers needed in order to get fog lights to work....
then make it a sticky in the this section so others can use this info as well...
Old Jun 11, 2013 | 09:13 PM
GTO 06's Avatar
Come on no one can help????
So many have done this 60+ have looked no one can help..
Old Jun 11, 2013 | 11:27 PM
GTO 06's Avatar
Default Parts needed in order to get your s70 fog lights to work
Parts you may or may not need depends on what you have so check it out before you buy them.
Volvo Fog Light Relay - Genuine Volvo 9148880
VOLVO Fog Light J Relay (s-70) - Genuine Volvo 9130269
Volvo Fog Lamp Switch (S70) - Genuine Volvo – 9162976
Volvo Fog Light Assembly Left (S70) - Genuine Volvo 9151785
Volvo Fog Light Assembly Right (S70) - Genuine Volvo 9151786
Volvo Fog Light Bulb 55W - Genuine 989811
Volvo Fog Light Grille Insert Lower Right (S70) - Genuine Volvo 9151510
Volvo Fog Light Grille Insert Front Left (S70) - Genuine Volvo 9151512
Old Jun 11, 2013 | 11:29 PM
GTO 06's Avatar
Default You do NOT need relay part number 213 "Fog Light Relay Jumper"
You do NOT need relay part number 213 "Fog Light Relay Jumper" for the fog lights to work on a 1998,1999,2000 s70
What you do need is a "J" jumper and "front fog light switch".
Instructions:
Step One:
Remove cover of drivers side kick panel by unscrewing single torx screw. Carefully push down kick panel till you have about one foot of clearance then gently pull toward drivers seat. Unplug courtesy light and toss the panel in the back seat.
This is where your midget contortionist skills come in to play.
Plug in "J" Jumper to Tan / Light Brown Relay port under dash.
Next to the steering wheel:
Pull off cover next to Rear fog light, behind the cover you will see a Yellow plug socket that is mounted to the cover. Remove the cover and replace with a Front Fog Light Switch.
With Key turned to position II turn on front fog light switch, if LED in switch lights up you are good to put fog lights on the car.
More info to follow:
Old Jun 11, 2013 | 11:32 PM
GTO 06's Avatar
Smile Make this a sticky
Please....
eccl1213
Sep 25, 2013 06:22 PM
sccadsr31
Dec 22, 2009 12:48 PM
mike322
Jan 9, 2006 07:59 PM
akbar
Nov 29, 2005 10:19 PM
rgarrett
Jun 16, 2005 03:08 PM
