Front axle bolt torque
Old 07-17-2010 | 02:24 AM
Blkwidow's Avatar
Default Front axle bolt torque
Does anyone know what it is?
Also wondering what the two control arm bolts are supposed to be torqued to as well as the ball joint.
thx
Old 07-25-2010 | 02:21 AM
Blkwidow's Avatar
any specs???
Old 07-25-2010 | 07:09 AM
What year S70?
Old 08-13-2010 | 03:20 AM
Blkwidow's Avatar
its a 99 s70 non turbo.
Old 08-14-2010 | 05:44 AM
Gcm's Avatar
Gcm
Hi, axle bolt is 89 ft/lbs, then a further 60 degrees of rotation. Lower inner control arm bushes are 13 ft/lbs, then a further 120 degreees of rotation. The bushes must not be torqued with the suspension hanging. They must torqued with the car's weight on them. ( that is at normal sitting position ) If you don't have the car on a ramp type lift it's a bit difficult to get a torque wrench in there. You can use a jack to jack the wheels and control arms up to normal ride height or run the front up onto ramps. Can't remember torque for ball joint - Good'n'tight should do !
Old 08-14-2010 | 01:25 PM
tr_car_nut's Avatar
Default axle bolt tightening
The axles on the 1999 S70 are different from the previous years (S70's and 850's). The bolt that holds the axle shaft to the hub is a small bolt that goes into the axle at the end rather then the large nut that holds the shaft at the hub on the 850 and the 1998 S70. This bolt is not as tight as the large nut on the earlier models. I also noticed on my 1999 S70 that there was some lock-tight on the threads of the bolt. You should however tighten this bolt with the wheel on the car and the car sitting on the ground. This will give you the best results for proper torque settings and not damage the transmission as you tighten the bolt.
Old 08-14-2010 | 08:20 PM
Gcm's Avatar
Gcm
OOPS ! - sorry about that. I see Tech's post indicating a difference now I look back.
Old 08-15-2010 | 08:46 AM
Ok I will look them up and post it soon.
Old 08-16-2010 | 11:38 PM
Blkwidow's Avatar
ok thx
Old 08-22-2010 | 03:20 PM
tr_car_nut's Avatar
I finally got the repair manual on DVD:
Applies to cars of model years 99-00:
Clean the hub and the drive shaft splines.
Fold out and twist the spring strut and locate the drive shaft in the hub. Use an adjustable wrench to hold the control arm down.
Install a new drive shaft screw.
Tighten to 35 Nm. Angle-tighten 90°. Counterhold the brake disc with a screwdriver.
Note! Lubricate the threads and flange on the screw.
Now the ball joint:
Check that the groove on the ball joint spindle lines up with the screw hole in the wheel spindle.
Note! Press the ball joint upwards so that the conical top is visible above the screwed joint on the wheel spindle.
Use a new locknut in the wheel spindle screw.
Tighten to 50 Nm.
For some reason it does not show the bolts on the frame side of the control arm. It only tells you how to change the bushings.
Old 08-26-2010 | 11:27 PM
Blkwidow's Avatar
thx for the reply.
Old 12-17-2021 | 11:19 AM
crabtreejohnn's Avatar
Default What do I torque down the the front axle to what pound
Originally Posted by tech
What year S70?
What do I torque down the front axle to on a Volvo
madymo3d
08-13-2014 01:05 PM
Counselor828
08-22-2011 01:19 PM
schnellcgw
07-29-2011 10:33 AM
kmellott
02-22-2009 06:01 PM
CRC1021
09-18-2008 10:03 PM
