FRONT STRUTS REPLACEMENT
Old Nov 29, 2007 | 11:28 AM
chachouu's Avatar
Banned
Default FRONT STRUTS REPLACEMENT
AFter I replaced front my struts,my passengert front tire which is almost new is kind of shaking now and a noise is comming out of the front end of the car,what,s most likely teh problem.
Old Nov 29, 2007 | 01:47 PM
Eric J's Avatar
Default RE: FRONT STRUTS REPLACEMENT
"new OEM strust and assembly part ,new tires ,new sway bar links "
AFter I replaced front my struts,,,,,,,,,,,,,,,,,,,,,,,,,what,s most likely the problem."
It's a guessing game, without being there.
I think you need a new front end mechanic. They should have got it right the first time.
Get it done before a wheel falls off.
If not:You've got to jack your car up to check it for play.(use a jack stand for safety)Have some one lift the wheel up and down with a 2x4 and look carefully for movement in the joints, Lower ball on control arm, control arm bushings, strut top and bottom(loose bolts?).Then have themmove the wheel left and right and look again, tie rods, control arm bushings, steering boxetc. Look everywhere.Then do the same for the other side. Let us know what you find.
Old Nov 29, 2007 | 03:38 PM
chachouu's Avatar
Banned
Thanks will do for the week-end
Porschenut
Apr 30, 2014 09:20 AM
_HighVoltage_
May 11, 2009 10:08 AM
chachouu
May 1, 2008 05:04 PM
hillfolk
Aug 10, 2006 09:18 PM
rejeep
Oct 16, 2005 12:47 AM
