FRONT STRUTS
Old Nov 17, 2007 | 07:39 AM
chachouu's Avatar
Banned
Default FRONT STRUTS
I am about to replace my struts,i have been hearing a noise on the passenger side,is there anything else i should change while I am it in regards to what might part of that noise.
Also can anyone suggest a Site with fairly good prices to get these stuff.
thanks
Old Nov 17, 2007 | 07:46 AM
jks2's Avatar
Default RE: FRONT STRUTS
http://www.fcpgroton.com/
Old Nov 17, 2007 | 08:04 AM
I would replace atleast the spring seats and maybe even the swaybar links. depending on how old they both are.
Old Apr 3, 2008 | 03:30 PM
alecw81's Avatar
A little over a year ago, I had the passenger side strut mount replaced, as well as the left and right axle-halves (CV boots were bad and this was a cheaper fix apparently).
Since then, the drivers side strut mount has gone bad as well, and I'll be replacing this as well next week. My Volvo mechanic (Becker in Durham, NC) suggested I replace the swaybar links as well, as the socket portion of the linkage was cracking. Does this sound right to everyone else? Tech?
I'm at nearly 202k miles on the odometer now, and just had the timing belt taken care of as well. I haven't had much else done to the car other than brakes, tires, and oil changes in the last 70k, is there something else I should be looking for?
Old Apr 4, 2008 | 09:45 AM
JimKW's Avatar
I would do the spring seats too. They cost next to nothing (about $25 each) and are known to go bad.
Old Apr 21, 2008 | 10:32 PM
JahMickey's Avatar
Parts.com has significantly lower prices and the web site is very user friendly.
Old May 1, 2008 | 05:04 PM
dane's Avatar
I just had the stuts on our 99 V-70 with 107k replaced. It was a rough ride, rattling and skimming noise when turning etc. After the replacement it rides better and the steering is great but sometimes the rattle is still there in the turns. I am wondering if they replaced enough of the items that make up the whole package. Are the spring seats the same as the strut mount bushings? Looks very similar on the pictures on-line. Is it hard to replace the struts on these cars?
Porschenut
Apr 30, 2014 09:20 AM
s70auto
Dec 3, 2007 06:00 PM
chachouu
Nov 29, 2007 03:38 PM
hillfolk
Aug 10, 2006 09:18 PM
rejeep
Oct 16, 2005 12:47 AM
