fuel and trunk switch
Old Apr 17, 2011 | 12:34 AM
SCStrat's Avatar
Default fuel and trunk switch
My 99 volvo s70's fuel and trunk switch in the driver side door is not working. Is it just a blown fuse? How can I fix it? Is there another way to open the fuel door?
Thank you
Old Apr 17, 2011 | 10:32 PM
Elchopperfreak's Avatar
I did it some time ago, I believe theres a latch inside the trunk.
Do not remember if in my case was the master switch or the central locking system.
Old Apr 18, 2011 | 12:23 AM
SCStrat's Avatar
I have tried finding the latch, but haven't found it. I read that it is in the trunk near the passenger side tail lights where the you replace the blubs, but I haven't found anything, even taking the bulbs out I still don't see anything.
I have a 99 volvo s70, does anyone know where the latch is to open the fuel door manually?
Old Apr 18, 2011 | 09:44 AM
you can overide it manually by pulling the lever hidden behind the carpet cover on right rear side (pull off the cover from right tail light and you will see a latch)
Old Apr 22, 2011 | 11:03 AM
pitrow's Avatar
I have that problem with mine occasionally, and what it is, usually the door lock/unlock switch in the front passenger door is sticky and partially depressed, and for some reason that makes the trunk and fuel door not work. If I jiggle the passenger door switch a little, then they work fine.
Might be worth a check to make sure none of your other switches are partially depressed, and see if that gets your fuel door working again.
Ryan911t
Apr 13, 2014 10:19 PM
qcvol
Jun 17, 2013 09:55 PM
Mie518
Apr 30, 2011 02:49 PM
Vincef
Mar 18, 2009 08:42 PM
curtisckey
Feb 25, 2008 05:39 PM
