Glove box key
Old Feb 4, 2009 | 07:17 AM
RPMCanes's Avatar
Default Glove box key
Shouldn't the ignition key fit?
Old Feb 4, 2009 | 09:04 PM
Yes it should.
Old Feb 5, 2009 | 07:30 AM
Somthngfrce's Avatar
It should, unless someone prior replaced the door from another car.. Had this happen to me once.
Old Feb 5, 2009 | 10:21 PM
Carrots's Avatar
Can you get the ignition key into the lock, and it just doesn't turn, or does the key not even go into the lock. If that's the case, then you have the "valet" key and not the "master key. The "valet" key operates only the door lock and ignition lock, but is cut to it won't physically go into the trunk or glove box lock. The dealer can order a new key (damn sidewinder keys) They're around $30 if you have a 1998 (non- interlock) and around $100 (plus programming) if your car is a 1999 or 2000 (interlock, RF chip in key head)
greenman86
Jul 9, 2019 11:48 PM
tech
Feb 2, 2014 11:52 PM
philiptory
Jan 1, 2012 08:01 AM
tech
Feb 24, 2005 07:51 PM
ahn2u
Feb 24, 2005 07:44 PM
