Groaning noise while turning
Old Oct 30, 2006 | 04:20 AM
hman613's Avatar
Default Groaning noise while turning
I have a 2000 S70 GLT. Operates fine when cold, but after driving for 20 or 30 minutes, I will hear a groaning noise when I turn the wheels (even slightly) to the left or right. The noise doesn't seem to be coming from the steering wheel area, and it gets louder the further I turn the wheels. I have verified that the power steering fluid is at the correct level. Any thoughts on what else to check?
Old Nov 2, 2006 | 09:38 PM
Default RE: Groaning noise while turning
Could be the rack or pump.
Old Nov 2, 2006 | 10:20 PM
hman613's Avatar
Thanks - what's a reasonable price to get the P/S pump replaced, if that is the problem?
Old Nov 3, 2006 | 12:27 AM
From experience the rack would be first to go bad.
But the pump is pretty expensive as well.
Old Nov 6, 2006 | 11:45 PM
sandders08's Avatar
ORIGINAL: hman613
The rack usually costs around $360. PS pumps are not DIY rebuild item and you can have the professionally refurbished one as a replacement. A core charge is usually asked for the new pump and when you bring the old pump for rebuild you can take back the charge.
Old Jan 4, 2007 | 07:05 PM
hman613's Avatar
Just an update - problem resolved. It was a bad P/S pump. Bought a refurbished one for about $150 (new is about $450-500) - and had the local mechanic install it for $160.
jollygoodgold
Mar 21, 2015 11:30 PM
98_V70_T5
Oct 11, 2009 05:17 PM
89240DL
Oct 3, 2009 12:59 PM
eyukins
Dec 21, 2007 08:10 AM
rp850
Jul 27, 2005 12:45 AM
