Help Identifying Front End Wires (Photos Attached)
I had to replace several front end pieces on my 98 s70 as a result of an accident a few months ago. The car has been in my garage where I have been working on it a little at time. I almost have all my replacement parts back on, but since it was a while back when I dismantled, I forget where some of the front end wires/connectors go. I know I should have marked or taped the wires in the beginning (lesson learned.)
Anyway, I need some help in knowing where the connectors with "red arrows” go (see photos). I know the "green arrows” are the main headlamp connectors, but not sure where I pulled these others from. The photos with the two "red arrows" is the driver's side. Appreciate the help.
RJB44
RJB44
Heres what I have- note I have been told I have an "odd" setup.. I have 1 big wire roll with 2 wires coming out at the 1st split. one goes to headlight and the other to the air pump connector- this one is grey male. The large roll continues and has the wiper connect-brown, another connect to some controller or splitter on the upper driver corner of the fan shroud, then a long connection to the AC relay which has 3 inputs, this one goes to the input on the far passenger side.
Does this help at all?
Specifically regarding the air pump- I replaced last summer. As I recall there is a connection on the air pump bracket itself, then another lead from there that leads to the metal in front of the battery tray with a grey to grey connection. What is really confusing is that it looks like the connector you are trying to identify, terminates right there
Hey, was under the S70 today and the Grey may go to foglights. Mine does not have foglights and terminates to a very similar looking cap. On the passenger side, it clips to the wiper washer reservoir
cyrusyn
May 31, 2012 01:35 PM
Lunger
Feb 26, 2012 07:11 PM
