High pitch fan noise
Old Feb 1, 2012 | 07:08 AM
Tychondrias's Avatar
Default High pitch fan noise
I own a 98 S70 and when I start the car up, particularly after I have not driven it in at least 8 hours, I get a high pitch "fan" sound that resembles a vacuum cleaner starting up. Sometimes it lasts 10 seconds, sometimes 30 and even up to a minute. Then it powers down, which sounds like shutting off a vacuum.
It is very loud and distinct and given the fact that it only happens after I have not driven in awhile, I wonder if it is something warming up in the car? It will usually only kick in when I start moving the car, and it only does it once per "session" of driving.
Does anyone know what is making this sound and if it requires any attention?
Old Feb 1, 2012 | 08:00 AM
Default Check valve and air pump
Found a video that someone posted with the sound that my car is making:
0316091653.mp4 video by cabbott709 - Photobucket
Looking into this further is leading me to believe that it is a bad air pump and check valve.
For anybody having the same problem, it is an easy repair, but the parts can be expensive. The cheapest air pump I've found was $330 and the check valve will run about another $100
Old Feb 1, 2012 | 12:14 PM
ed7's Avatar
ed7
Volkswagen uses a similar pump with slightly different mounting plastic parts. I've seen a write-up of the guts swap, but can't remember the location. Don't be averse to hitting up the junk yards.
Ed- Chicken Engineer, Mississippi State '88
Old Feb 1, 2012 | 12:57 PM
Good call, will probably hit up the junkyard after I fix my axles/hub bearings
Here is a good thread on this topic (bad air pump noise) for reference if anybody needs:
98 S70 Makes Weird Noise - Volvospeed Forums - Page 2
benjamin227
2001-2013 model year V70
Oct 29, 2013 09:57 AM
mandobizar
Dec 20, 2011 10:12 AM
dongwenxuan
Jul 20, 2011 09:45 AM
volvovera
Feb 11, 2011 07:18 PM
JimKW
Aug 22, 2009 08:54 AM
