Hood Latch
Old Jan 26, 2009 | 01:40 PM
wvuboy0207's Avatar
Default Hood Latch
I tried to open up the hood on my 98 S70 and only the passenger side releases. The drivers side doesn't release. I live up in Buffalo, NY and it is fairly cold out. Could it have anything to do with that?
I was able to open it just last week know problem. I also took it for a car wash when it was 40 out last week and it gets parked outside so perhaps it froze??
Anyone have any cures for this?
Thanks
Adam
Old Jan 26, 2009 | 08:42 PM
s70_t5_1999's Avatar
Default RE: Hood Latch
try driving it for 30 minutes or so and try again. make sure the other side is relateched before driving. also, wiggle the hood popper a little bit, i know mine can be fussy sometimes
Old Jan 27, 2009 | 05:26 PM
FredMc's Avatar
Same exact thing as me. I got a procedure copied and downloaded from matthews volvo site I think to correct it.
The lenght of the metal "cord" if you will that attaches to the latch opener inside the cabin to the latch releases on both sides of the hood is stretched and needs to be tightened one or two turns.
you have to remove the panel below the steering column and then the side panel near your left foot carpet side to get to it.
I printedthe procedure out. But cannot scan it for you.
Old Jan 27, 2009 | 05:29 PM
FredMc's Avatar
what I did for two months is open it with a bungee attached to the grill in the garage for tension and then pulled the latch, and it would spring up.
Or had a friend gently pull up on the grill/hood while I pulled the rip cord. It works.
Then I fixed it the right way.
Old Feb 3, 2009 | 04:53 AM
Dartquetee's Avatar
Default Hood Release
I have the same problem.. what I do is pull the hood release,then go pull up on the hood a bit, then go pull the hood release again and that will release the driver side of the hood... maybe this will work for you too.
Sometimes you don't have anyone to help by pulling up on the hood while you pull the hood release..so maybe this will help.
Old Feb 3, 2009 | 07:01 PM
elcs70's Avatar
hmmm, my hood latch seems to be getting "weaker" for lack of a better word, should i be worried about it breaking, or will it just continue to stretch?
JeannieBeannie
Mar 6, 2019 01:29 PM
850TurboWgnPlatEd
Nov 5, 2008 12:52 PM
dougsnow
Apr 22, 2006 07:07 PM
salkenn
Nov 19, 2005 02:59 PM
trehux
Aug 10, 2004 07:01 PM
