How do I get my radio back on?
Old Apr 14, 2006 | 06:34 PM
jgarvey's Avatar
Default How do I get my radio back on?
My radio says "OFF". I have the code to get it back on. The dealership told me to leave the car running for two hours then put in the code. I left the car running two hours, but didnt get the "ENTER CODE" prompt. Instead, it still says "OFF". What do I need to do???? Thanks in advance.
Old Apr 14, 2006 | 07:14 PM
FLATRATE's Avatar
Default RE: How do I get my radio back on?
you need to have the ignition on for about 2 hours...ignition on pos. 11 and you should be ok. if not something is wrong with your radio
Old Apr 14, 2006 | 07:19 PM
jgarvey's Avatar
Thank you flat rate. Part two of the question. If my battery happens to die during the two hours that the ignition is on... could that be a reason it would not change to "ENTER CODE"? Also, is it exactly two hours or between two and three hours? Because when I tried it last week, I drove around and then left the car in park running for two hours and twenty minutes and the code never changed to"ENTER CODE". Do I need to keep the radio turned off the entire time I am going through this two hour thing? Sorry so many Qs...I am just at a loss.
Old Apr 14, 2006 | 07:20 PM
FLATRATE's Avatar
the radio needs to be on, the car does not need to be running, and usually it doesn't take 2 hours but that's approx.
Old Apr 14, 2006 | 10:04 PM
With the key in positing 1 the only power being used is for the Radio and the SRS light I believe.
Unless the battery is weak from the start you will be fine.
Keep an eye on it till it says code. I have seen it take up to 4 hours.
Make sure you get the proper code from your local Dealer.
rico
May 22, 2009 11:40 PM
cheramy
Apr 13, 2009 09:12 PM
chopsieze
Sep 18, 2008 09:08 AM
throw1back
Mar 20, 2008 09:29 PM
ludeless
Dec 17, 2005 07:14 PM
