How much oil do I need
Old Oct 10, 2007 | 04:56 PM
alireza1344's Avatar
Default How much oil do I need
Hi there
I want to change the oil on my 1999 S70 AWD. Can somebody tell me how much oil do I need?
Also do I need to use Volvo filter or I can buy anything from costco?
Old Oct 10, 2007 | 05:37 PM
ocean238's Avatar
Default RE: How much oil do I need
5.8 liters according to owner's manual, check out the specification section of your owners manual if you have it just in case!
hope it helps
Old Oct 10, 2007 | 05:45 PM
NathanS70's Avatar
6.1 quarts of oil will do. I use a NAPA Gold Edition filter w/ Amsoil fluid. I change the filter every 3k miles and the oil every 9k miles.
I beleive a turbocharged model requires less quarts, but I may be wrong. Your owners manual should state that.
Old Oct 11, 2007 | 02:39 AM
JPN's Avatar
JPN
As for the filter, I would go with MANN; the OEM filter.
http://www.fcpgroton.com/CSV70/csv70tuneup.htm
If you prefer to go with something else, make sure that the filter comes with internal check valve.
Good luck,
JPN
Old Oct 11, 2007 | 08:03 AM
Thanks a lot
nilo
Aug 18, 2012 10:25 AM
Ianpaul
Jan 11, 2012 10:09 PM
boggy
Nov 4, 2011 08:22 PM
rspi
Dec 20, 2010 09:47 PM
aryanvahedi
Nov 18, 2009 08:59 PM
