HVAC Switching issue
Old Oct 16, 2013 | 08:39 AM
fonebone77's Avatar
Default HVAC Switching issue
I looked around and I didnt see any posts specific to the S70. When I change the HVAC from vents to defrost the air continues to come out the vents. I hear something happening in the dash when I do it (maybe like the door moving) but it doesnt actually change the flow. I can shut all the vents and get enough flow for the defrost to work but I would like for it to work correctly. Any suggestions would be appreciated!
Old Oct 16, 2013 | 09:00 AM
There is a lever behind the dash that breaks stopping the motor from moving the arm that changes the flow. You will need to pull the glovebox to get at it and replace the part.
Old Oct 16, 2013 | 04:19 PM
fonebone77's Avatar
Thanks rspi. I will check that out. I used your vids on replacing the blower motor and also the antenna mast. Good stuff!
Do you happen to know what that part is called or maybe a part #?
Maxbaby
Dec 24, 2011 09:38 PM
tn850
Dec 5, 2007 07:20 PM
Maxbaby
Apr 18, 2007 03:16 AM
850forum
Feb 25, 2007 01:51 AM
Air Defender
Mar 2, 2005 02:29 PM
