idle?
Old Jul 1, 2008 | 03:13 PM
elcs70's Avatar
Default idle?
so, when i am driving my 99 s70 with 160k miles down the highway at 60 or so mph, and i let of the accelorator, the tach fluctuates between 1200 and 1800 rpm's, then finally settles to 1500. why is this? when i shift into neutral while examining this the rpm's immediatly drop to 900 which i belive is normal. it also idles fine at 900 when in park or sitting still in drive.
Old Jul 1, 2008 | 04:56 PM
jsj_297's Avatar
Default RE: idle?
Sounds like throttle body/IAC valve problem, or a pretty bad primary vacuum leak. Try cleaning Throt. body, and IAC valve see if it helps at all.
matt01
Dec 4, 2011 10:53 AM
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
