IGNITION KEY
Old Sep 11, 2007 | 12:27 PM
elidari's Avatar
Default IGNITION KEY
Hi,
I'm having a problem when I turn off my engine the key will not come out, I have tried every thing in the book (I even tried praying) any suggestions will be appreciated.
If I need a part can anyone suggest to buy the part, and what part is needed.
Thanks,
Eli
Old Sep 11, 2007 | 03:09 PM
S70driver's Avatar
Default RE: IGNITION KEY
I hate to suggest it but are you sure the key is turned all the way back so it is able to come out.
Old Sep 15, 2007 | 06:58 AM
That is usually either the shift **** is bad or the shiftlock bypass button is stuck down some.
Old Sep 19, 2007 | 01:14 PM
RPMCanes's Avatar
Yes, make sure your gear selector is firmly in park, and if it is, you may have a bad ignition swich. So far, on my 98 S70GLT, I'm on my second.
Old Sep 23, 2007 | 10:39 PM
Sixdown's Avatar
I had the problem a year ago when I first bought my 98 S70. My shiftlock button didnt release it so I did these steps:
1.Put car in neutral while the engine is obviously running.
2.Let the car roll backwards (you may have to get out and nudge it or get someone to push it) for three or so feet.
3.Get back into the car if not already, and put the gear into park.
4.You should be able to remove the key now.
It might also be fixed by pushing the shifter up and down repeatedly through all gears and back to park. Do this quite a few times and it might release the key.
dodgerkcj
Jul 2, 2018 11:41 AM
Ricardito
Aug 14, 2012 08:29 PM
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
