immobiliser problem
Old Feb 24, 2012 | 10:21 PM
kennedy759's Avatar
Default immobiliser problem
2000 S70 glt, looks like I might have an immobiliser ring problem, where can I buy a replacement or do I have to match up to the key? any insight will be welcome.
Old Feb 26, 2012 | 09:37 PM
kennedy759's Avatar
anyone??
Old Feb 27, 2012 | 05:25 AM
bw77's Avatar
The antenna ring reads the chip inside the key. You can try a different
key, or you can try cleaning the contacts. Or replace the ring.
eEuroparts - Starter Immobilizer - # 9442961
Old Feb 27, 2012 | 09:07 AM
kennedy759's Avatar
thanks, does it have to be reprogrammed to match the chip in my key?
Old Feb 28, 2012 | 05:40 AM
bw77's Avatar
No, it just reads the chip.
Old Feb 28, 2012 | 11:28 AM
kennedy759's Avatar
antenna ring ordered, I tried a different key and still had problems, any idea why this only happens some of the time while some of the time it starts without any problems?
Old Mar 1, 2012 | 08:16 PM
kennedy759's Avatar
got it and installed it, so far so good, looks like some previous owner needed to get in there since some of the tabs were broken on the plastic covering the steering column. the paint on the screws to the wiper stalk were marred. any way, the whole ignition switch, wiper and cruise stalk assembly was a little bit loose around the steering column, is that normal, or do I need to go back in and try and tighten it.
biteydog
Aug 26, 2018 07:25 PM
Stefan v50 2.0d
Mar 21, 2013 04:12 PM
bwaarp
Mar 27, 2009 03:15 PM
scott_mcevoy
Jan 14, 2006 07:01 PM
albini13
Jul 10, 2005 09:25 PM
