install driving lights
Old Jan 23, 2009 | 10:48 AM
michaeldvo's Avatar
Default install driving lights
Bought a kit for install of drving lights. have installed mounted to license plate bracket. need help in getting switch wire thru firewall and where to install switch on dash. also any other points that I should be aware of.
Old Jan 23, 2009 | 11:05 AM
S70driver's Avatar
Default RE: install driving lights
1. There should be a black gromet on the drivers of the firewall to pass it through.
2. You should hook them up so that they are on when your LOW beams are on. So if you have your DRL's on they are not on and if you have your DRL's disabled then they are not on. Just on when your LOW beams are on.
3. If you don't like that idea... Run the switch to a blank spot on your dash area.
timxxx
Dec 21, 2009 01:20 PM
schigara
Oct 13, 2009 11:36 PM
markjenross
Jul 1, 2008 08:03 AM
kdlong72
Feb 19, 2007 10:56 PM
SpecterV70
Dec 16, 2006 03:07 PM
