instrument cluster dead Plus ETM trouble
Old Feb 25, 2011 | 10:12 AM
mark_disfree's Avatar
Default instrument cluster dead Plus ETM trouble
Hey All,
I have a 99 S70 T5 showing all the classic signs of a bad ETM module, (ETS and “check engine light” are on, rough idle, turbo is no longer working) but additionally my dash gauges are dead.
From everything I have read this seems like the recalled ETM issue, except when I called Xemoddex they said the dead gauges were not the ETM and something additional must be wrong.
They suggested a bad relay under the dash could be the culprit and that I could test it by swapping it with an identical relay that controls the radio & climate control ( also found under the dash). I tried this but saw no change.
So what I am asking is for ANY possible causes for a dead dash.
Thanks a bunch.
Old Feb 25, 2011 | 01:29 PM
Carrots's Avatar
Check all the fuses. Use a "fuse tester" or a multimeter on the continuity setting to avoid pulling and looking at all of them.
Old Feb 25, 2011 | 02:25 PM
Good call on checking the fuses. I looked before but after pulling a bunch I kinda just glanced at the rest. I will use my multimeter and look again. Anyone have a clue which fuses might relate to the dash?
dmtri07
Mar 23, 2023 11:30 PM
twbennet59
2001-2013 model year XC70
Sep 9, 2013 01:29 AM
volvo5volvo
May 29, 2012 05:46 AM
laronsue2
Nov 30, 2010 10:55 AM
rbroy
Jan 31, 2010 08:10 PM
