Interior Rear Seat Map/Dome Lights Not Working with LED bulbs.
Old Feb 17, 2016 | 10:21 PM
Ben_25's Avatar
Default Interior Rear Seat Map/Dome Lights Not Working with LED bulbs.
So I decided to convert all the interior bulbs to LEDs. The two by the driver and front passenger work, but I tried the ones in the back but they don't. Plugging in the old incandescent bulb works still, but the LED ones do not work. I got the correct size and everything. Any help?
Old Feb 18, 2016 | 09:46 AM
firebirdparts's Avatar
Did you turn them over? They are polarity sensitive. You got a 50/50 chance of them coming on when you install them.
Old Feb 19, 2016 | 12:15 PM
Ben_25's Avatar
Tried that already. The ones in the front work just fine, but the ones in the back seat don't light at all. Also, I tried swapping the glovebox bulb out for an led one, but that one didn't work either.
Old Feb 19, 2016 | 08:19 PM
How are you turning them on?
Did they work before?
Old Feb 20, 2016 | 11:39 PM
Ben_25's Avatar
They turn on when the doors are open.
Old Feb 26, 2016 | 06:15 PM
gregorv's Avatar
I tried doing this to my S70 a couple years ago and ran into the exact same problem. I was dumbfounded and just ended up putting the incandescent bulbs back in because I got so frustrated.
Old May 26, 2018 | 07:00 AM
Brad Hovan's Avatar
Default Same Experience
When installing new LEDs I encountered the same issue, and yes even when the door was open/close the issue ensued. Will trying disassembling and cleaning connectors i guess... S70 btw
Old Aug 20, 2019 | 02:24 PM
Joe Gson's Avatar
Default same issue
I am sat in my S70 attempting to replace all interior lighting with LED bulbs. Front interior ceiling lights work no problem but the rear ceiling lights will not work with LED bulbs!
Did anyone figure out a solution? It's not a problem with polarity!
Old May 22, 2022 | 08:44 AM
Odenkurtiak's Avatar
Try to buy LED panel car interior lamp DC12V. They have pretty good life guarantee and extra feature that makes reducing brightness. Also you do not need to change bulbs frequently which is extremely convenient. I purchased
car lighting car lighting
here from Amazon and from my own experience, I can say that these lights are bright for real! Great for lighting up vehicle interiors or making a work light for precision projects. I also plan to use them as back lighting for shadow boxes. In addition, what I personally enjoyed, I'm very lazy person and they are very easy to install, just plug and play.
Old Jun 25, 2022 | 07:32 AM
patcal's Avatar
These are the ones I used in my 98 S70. Worked fine although they are not quite as bright as I would like. Definitely a improvement over stock.
Amazon Amazon
Old Jun 25, 2022 | 07:34 AM
patcal's Avatar
Sorry. I did not notice the date before I posted.
Old Jun 25, 2022 | 09:49 AM
Psaboic's Avatar
No worries, I found the info useful as I have had the LED issue for years.
Old Aug 30, 2022 | 02:22 AM
Kenken's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Did these work in the glove box and rear seat lights? My won't work with led. Tried two different bulbs.
blitz92
Dec 14, 2015 07:21 PM
DMac
Feb 19, 2014 11:08 PM
mirekj
Mar 19, 2013 08:57 AM
Dakabaks,S70
Feb 20, 2011 05:55 PM
bond007
Jan 24, 2011 01:25 PM
