Just got my '98 s70 glt - lots of q's
Old Apr 20, 2007 | 02:40 AM
  #81
S70driver's Avatar
Default RE: Just got my '98 s70 glt - lots of q's
ORIGINAL: samadkins29
it does say universal, its just has some car types to get more hits
also what would I need to install that? I am not sure if the upper ic is metal on mine
1. You would need an ALUMINUM flange that fits the UNIVERSIAL HKS SSQV. And a length of vaccum line.
2. To check if your Upper IC pipe is ALUMINUM. All you have to do it tap it with a screwdriver or something else that is metal. You will instantly know.
Old Apr 20, 2007 | 02:44 AM
  #82
samadkins29's Avatar
what did you do with the stock blow off valve?
Old Apr 20, 2007 | 02:46 AM
  #83
S70driver's Avatar
There is no stock BOV.
It is called a CBV. I left mine be. I am running both a CBV and a BOV.
You can do this what I did and or block the CBV off with what is called a Blanking Plate. Which can be bought from, http://www.quickbrickmotorsports.com/prod_blanking.html
Old Apr 20, 2007 | 02:50 AM
  #84
so a 60mm aluminum flange would be ok? with the blow off valve I showed which is teh same one they are selling on teh HKS site
Old Apr 20, 2007 | 02:51 AM
  #85
S70driver's Avatar
I have no idea what size flange would be ok for the HKS SSQV. Whatever UNIVERIAL ALUMINUM flange that is suppose to go with that UNIVERSIAL HKS SSQV.
Contact HKS and ask them.
Old Apr 20, 2007 | 02:56 AM
  #86
edited last post agian
but yeah, ill do that
Old Apr 20, 2007 | 02:57 AM
  #87
S70driver's Avatar
Again contact HKS and ask them. I have no clue what size flange you need. I do know is that you need an ALUMINUM flange to weld to your ALUMINUM Upper IC Pipe.
Old Apr 20, 2007 | 02:58 AM
  #88
to change the subject, their is an ECU upgrade here (s70 2.4T) and was wondering if you might know if this was designed for a stock engine or would I need ot buy more parts?
Old Apr 20, 2007 | 03:00 AM
  #89
S70driver's Avatar
That is a SpeedTuning USA ecu upgrade. I have one for my car. You can run that ECU upgrade stock, but I wouldn't. It would be better if you had supporting mods though.
DON'T DO AN ECU UPGRADE UNTIL YOU HAVE DONE EVERYTHING ELSE. Unless you don't plan on anything else.
I personally want to do more to my car, but I know money wont allow it. That is why I have an ECU upgrade right now with no supporting mods like a upgraded downpipe and exhaust system.
Old Apr 20, 2007 | 03:03 AM
  #90
(same here, for the time being)
am looking to do the blow off and ecu upgrade for starters, then get teh high flow air filter and air intake.
Old Apr 20, 2007 | 03:04 AM
  #91
S70driver's Avatar
Ok do what you want, but what I am telling you is to do the ECU last. You will be better off and also take full advntage of all of the potential power from all the supporting mods.
Also a BOV on your car wont add any performance, it is just a noise maker. Same as mine is.
Old Apr 20, 2007 | 03:08 AM
  #92
ORIGINAL: S70driver
Well basically its like you said, money wont alow. I know the bov wotn add any performance but I like teh sound so after that and a ECU upgrade I wont really have any more money for awhile. AS fora full stage zero, I had the car check out and they siad everyhting was running fine(except for teh air pump), so will replacing working parts really help?
Old Apr 20, 2007 | 03:10 AM
  #93
S70driver's Avatar
ORIGINAL: S70driver
Well basically its like you said, money ownt alow. I know the bov wotn add any performance but I like teh sound so after that and a ECU upgrade I wont really have any more money for awhile. AS fora full stage zero, I had the car check out and they siad everyhting was running fine(except for teh air pump), so will replacing working parts really help?
Replacing your OEM turbo hoses with Silicone turbo hoses will and same goes for the OEM rubber vaccum lines. Upgrading them to Silicone versions will help as well. Holds boost better. Also when you upgrade the turbo hoses get T-BOLT clamps they are much better then the OEM hose clamps.
Old Apr 20, 2007 | 03:11 AM
  #94
ah ic, so out fo the stage zero list those would be the two things that should be done. Also i am nto sure but teh vacume lines might ahve been replaced already by teh previous owner. I can get some pics of the engine tmrw is you would like?
Old Apr 20, 2007 | 03:13 AM
  #95
S70driver's Avatar
ALL of it.
I'm out for tonite.
Old Apr 20, 2007 | 12:43 PM
  #96
S70driver's Avatar
STAGE ZERO is very important. It gets your car up and running to good standards. You don't have to do it, but it is a good idea to do it if your planning on what you are planning on doing in the future.
I would at least do the SAMCO turbo hoses w/T-Bolt clamps and silicone vaccum lines.
Old Apr 20, 2007 | 02:05 PM
  #97
Plugs
cap/rotor
oil/transflush - Oil and trans fluids are good
filter (oil) - Oil filter still good
hoses (the little vac lines)
samco hose kit
02 sensors - still good
fuel pumps - still good
clean injectors
clean IC/IC plumbing
Air Filter - still good
plug wires
Dunno what the other stuff is, but I had the car checked out by a volvo mechanic and firestone. Neither of them mentioned that any of the other things would need ot be replaced. I will check those hoses.
Old Apr 20, 2007 | 04:32 PM
  #98
S70driver's Avatar
Plugs
cap/rotor
samco hose kit
clean injectors
plug wires
At least get the SAMCO's and Stylin Motors Inc. vaccum lines. If you go the welded BOV route go with the Stylin Motors Inc. turbo hoses and vaccm lines as well.
Old Apr 20, 2007 | 08:15 PM
  #99
well thats the question I have, teh vac lines seem to have been replced. Since they are a differnt color. If I took a pic of teh engine would you be abel to tell em if you think they are stock or not? and yes my upper ic is aluminum, got confused since its painted black like all teh otther rubber hoses.
Old Apr 20, 2007 | 09:24 PM
  #100
S70driver's Avatar
What color are the vaccum lines?
