Just got my '98 s70 glt - lots of q's
Old Apr 17, 2007 | 12:37 PM
  #61
samadkins29's Avatar
Default RE: Just got my '98 s70 glt - lots of q's
Well it should be accurate, selling one that wasnt accurate can get people killed. Basically in addition to the hose mountings and all that thier is a another black piece that has a hose connection. So you stick the vac line into that and it reads it and then you connect the wires from that into the gauge.
OK thats not exactly what it looks like but you can get the idea. On the black box you have the the vac line connection and then you ahve the electrical wires running from it to the back of teh gauge. Its a much more complicated setup pictured. But like I said, you can get the idea.
Old Apr 17, 2007 | 03:54 PM
  #62
S70driver's Avatar
So it still looks like you need to run a vaccum line anyways.
Oh well.
Old Apr 18, 2007 | 01:03 AM
  #63
well teh exact back of it was pictured before, the second pic was to give you an idea for what I am talking about. You run the vac line to sensor in the engine.
I can take a pic of everything i received if you want.
Old Apr 20, 2007 | 01:36 AM
  #64
hey what blow off valves fit on the s70? with little or no modification
Old Apr 20, 2007 | 01:50 AM
  #65
S70driver's Avatar
There is no blow off valve that is really made to fit Volvo's. I lie, there is one, but IMO I would go for having an HKS SSQV and the Aluminum flange welded to the Aluminum upper IC pipe.
1. DO NOT buy TURBO XS BOV's.
2. Buy an HKS SSQV and have the flange welded onto the Upper IC pipe.
3. If you can't have someone wled a flange look into the only other option. Buy this SAMCO turbo hose seen here...
Which can be bought from Viva Performance. And buy the SAMCO BOV that fits into it. Which is pictured here...
Which can also be bought from Viva Performance.
Old Apr 20, 2007 | 02:01 AM
  #66
I ahve the pics of the gauge and stuff, do u want me to post?
Old Apr 20, 2007 | 02:03 AM
  #67
S70driver's Avatar
ORIGINAL: samadkins29
Yeah please do.
Thanks
Again I would suggest going with a Universial HKS SSQV and having the flange welded to your upper IC pipe. Like mine, but mine is a TURBO XS BOV. I know I told you not to go with them. Why do I have one then? Because it was cheap and I didn't know any better. I bought it from a fellow Volvo lover who used it and I bought it cheap. Well they are prone to leaking. I believe mine does.
Old Apr 20, 2007 | 02:08 AM
  #68
only problem with teh welding is that I dont know any place to ahve it done around here. Its hard enough to find a performance shop to work on my volvo(which i ahve not been able to find)
Here are the pics:
Pic one is of the boost sensor and air filter
Pics two is of the four wires coming from the gauge and the pvc hose
Pic three is the install instructions
Old Apr 20, 2007 | 02:10 AM
  #69
S70driver's Avatar
I'm sure you have a local shop that can weld.
They have to be able to weld Aluminum. If you find a place that can, go that route please. If not go the Viva Performance route that I mentioned above.
Old Apr 20, 2007 | 02:18 AM
  #70
how much does welding cost?
Old Apr 20, 2007 | 02:19 AM
  #71
S70driver's Avatar
Mine was $60 to have the Aluminum flange welded onto my Upper IC pipe.
I would expect anywhere from $50-$150.
Old Apr 20, 2007 | 02:20 AM
  #72
ah ic
Old Apr 20, 2007 | 02:21 AM
  #73
S70driver's Avatar
ah ic
You can buy a Universial HKS SSQV for $160. I forget if this includes the right flange or not. Then another $50-$150 for welding of the flange.
Old Apr 20, 2007 | 02:24 AM
  #74
what does teh HKS SSQV mean? Also I look on viva perfmance and it seems you cant get just that hose part you pictured? Have to get the entire kit?
Old Apr 20, 2007 | 02:27 AM
  #75
S70driver's Avatar
1. "The HKS Super Sequential Blow-Off Valve (SSQV) is a dual stage pull-type relief valve. Unlike typical push type blow-off valves, the SSQV will not leak under any level of boost because the boost pressure in chamber "C" keeps the valve closed against its seat (Diagram 1). The SSQV releases excess boost when there is a pressure alteration in chambers "A & B", not by the rate of boost pressure or vacuum in the line. This ensures a quick valve response and complete closure during idle. Many competitors use a push-type blow-off valve design with a large valve to accommodate high boost / high horsepower applications. These large valves react slowly and require high pressure to open, and are not able to activate and prevent compressor surge at light-load conditions. On the other hand, smaller, fast reacting push-type valves do not discharge the airflow capacity required for high horsepower applications and tend to slowly open and leak as boost pressure overpowers the spring. For maximum performance, the HKS SSQV incorporates both a small primary valve for ultra quick activation, and a larger secondary valve for additional discharge capacity. The SSQV is engineered to initially open the small primary valve at light throttle and load conditions (Diagram 2), then sequentially opens the secondary valve for additional relief capacity under high boost and load conditions (Diagram 3). The SSQV is constructed of polished billet aluminum, which ensures long-term durability and a high luster look. The mounting base utilizes a circular mounting flange that combines with a C-clip snap ring and O-ring gasket to insure an excellent seal. The triple-fin discharge port design produces a powerful, unique and aggressive blow-off sound. The HKS SSQV is available in vehicle specific kits or as a universal unit for custom applications. Vehicle specific HKS SSQV kits come complete with all mounting flanges, brackets, and miscellaneous hardware for an easy installation. For Universal SSQV applications, weld-on flanges are available in steel or aluminum for custom installation."
2. Well I would get the entire kit. That is part of STAGE ZERO. Silicone turbo hose upgrade.
Old Apr 20, 2007 | 02:31 AM
  #76
This work?
Old Apr 20, 2007 | 02:33 AM
  #77
S70driver's Avatar
This work?
I wont say yes and I wont say no.
I suggest you look for one that says UNIVERSIAL HKS SSQV.
Old Apr 20, 2007 | 02:34 AM
  #78
it does say universal, its just has some car types to get more hits
also what would I need to install that? I am not sure if the upper ic is metal on mine
Old Apr 20, 2007 | 02:36 AM
  #79
S70driver's Avatar
Then get it.
Old Apr 20, 2007 | 02:37 AM
  #80
edited last post
