Just got my '98 s70 glt - lots of q's
Old Apr 24, 2007 | 12:47 PM
  #161
S70driver's Avatar
Default RE: Just got my '98 s70 glt - lots of q's
If you notice my intake manifold is different then yours.
Also I have an ETM (Electronic Throttle Module). Meaning electronic throttle body. While you have a regular style throttle body.
I do not have a vaccum tree on my car, you do and or should. The vaccum tree on your car can be found underneath the throttle body cover.
Old Apr 24, 2007 | 06:09 PM
  #162
samadkins29's Avatar
ok ok, thats what that is, I did notice that between the two cars mine had that cover.
Old Apr 24, 2007 | 06:16 PM
  #163
S70driver's Avatar
ORIGINAL: samadkins29
Yeah and if you remove that cover you will find the vaccum tree.
Old Apr 24, 2007 | 07:25 PM
  #164
I dunno which is the vac line:
Old Apr 24, 2007 | 07:40 PM
  #165
S70driver's Avatar
Crap your engine is dirty.
It isn't # 2 or 3. But I can't say 1 is a vaccum line.
Old Apr 24, 2007 | 07:42 PM
  #166
ORIGINAL: S70driver
HAHA, yes it is, only had teh car for a few weeks, so its not completely my fault.
Old Apr 24, 2007 | 07:46 PM
  #167
S70driver's Avatar
ORIGINAL: S70driver
Clean it up please. It needs it badly and you will feel better.
Old Apr 24, 2007 | 07:47 PM
  #168
S70driver's Avatar
This is what your vaccum tree should look like.
Old Apr 24, 2007 | 07:49 PM
  #169
ORIGINAL: S70driver
If i took a short video of the #1 line show you where it goes, would that help? (or more pics)
**Edited**
Ok I will go and look for that
Old Apr 24, 2007 | 07:51 PM
  #170
S70driver's Avatar
ORIGINAL: S70driver
**Edited**
Take your throttle body cover off and you will see the vaccum tree. And there should be some places that have a small black cap on them. Use those spots to hook your boost gauge up to and your BOV when you get it. Take the black plug off and connect what you need to connect.
Old Apr 24, 2007 | 07:59 PM
  #171
I found that, had teh cover off before, jsut took a pic of the wrong hoses.
Old Apr 24, 2007 | 08:21 PM
  #172
pic uploaded
Old Apr 24, 2007 | 08:58 PM
  #173
S70driver's Avatar
What I have circled in RED is the useable vaccum spots.
Old Apr 24, 2007 | 08:59 PM
  #174
ok, kewl, thanks!
Old Apr 24, 2007 | 09:01 PM
  #175
S70driver's Avatar
ok, kewl, thanks!
No problem.
Old Apr 24, 2007 | 09:12 PM
  #176
I didnt think it was gonna be that easy, I wont even need to use the T fitting and only one vacline connector. I guess all thats left is the electrical, I wont ask you to get into that since you didnt install it yourself. Actaully I guess I ahve one more question, I can hook my boost PVC line directly to that right? I think you said taht I would, I jsut wanted to double check.
Old Apr 24, 2007 | 09:25 PM
  #177
S70driver's Avatar
No you cannot just hook your PVC line to one of those unused spots. You run the PVC line to there but you use one of those things your friend said you would need. There is an example of it right underneath the two front vaccum tree spots.
Old Apr 24, 2007 | 09:29 PM
  #178
o ok, jsut wanted to check, yeah I have two of those. Thanks again, and ill post if I get mroe questions.
Old Apr 24, 2007 | 09:32 PM
  #179
S70driver's Avatar
Ok cool
Old Apr 25, 2007 | 12:52 AM
  #180
ok, heres a question, dunno if ya know the answer but I thought I would give it a shot. If you reffer back to apge 15, the picture I posted with what I thought was teh vaccum line. Is that "can" the bybass valve? and if so I would repalce that with a blow off valve correct? I also had another thought, if i took off the line thats going to it would it make the blow off sound?
