Just got my '98 s70 glt - lots of q's
Old Apr 25, 2007 | 06:33 PM
  #201
S70driver's Avatar
Default RE: Just got my '98 s70 glt - lots of q's
ORIGINAL: samadkins29
but running rich for a split second wont really have any affect, since its low psi setup. "Worsens with higher boost pressure", just want to make sure that if I do do this, it not putting even mroe stress ont eh car than not having one is.
Upgrading your car with anything engine wise is putting more stress on the car. But running RICH for that split second wont be too too bad of a problem.
Old Apr 26, 2007 | 01:14 AM
  #202
samadkins29's Avatar
yeah true, well Ima pass on the BOV for now, jsut gonna get the boost gauge installed, K&N air intake, and speedtuning ecu upgrade.
Old Apr 26, 2007 | 01:49 AM
  #203
S70driver's Avatar
Ok cool.
This is why I said a shop needs to install your BOV. Unless you do the SAMCO route.
Old Apr 26, 2007 | 02:23 AM
  #204
well i was already going to ahve a shop do it for the welding, I just like to know as much about my car as I can learn. But for now, my money can be used better, like for the intake. i am also picking up those turn signals liek the ones you have. Those can use the stock turn bulbs I have now right? I am assumign they are the same size since I dont why they wouldnt be.
Old Apr 26, 2007 | 11:18 AM
  #205
S70driver's Avatar
Yeah they can use the same turn signal bulbs.
Are you picking up the ABM Chrome Projector style turn signals like I have now or the E-codes?
Old Apr 26, 2007 | 11:29 AM
  #206
the ABM projector style, I like them better than the e- codes. Mainly because they look more after market than e-codes.
Old Apr 26, 2007 | 11:33 AM
  #207
S70driver's Avatar
1. Where are you buying them from?
2. Fair warning. They do not come with the actual bulb holder. You have to take the bulb holder from the OEM turn signals and use it in the ABM's. Also you have to modify the turn signals just slightly to allow the OEM bulb holder to fit properly. By filing one of the slots just slightly. Now that they have been on for a few months I forget which slot it was but you can figure it out.
Hopefully your going to get the matching headlights then as well like mine.
Old Apr 26, 2007 | 11:37 AM
  #208
yeah I will, eventually. The turn singals are the last thing on my list atm. looking at air filters, ecu, and other engine components first.
Ebay, if I where to buy them would be where I get them.
Old Apr 26, 2007 | 11:54 AM
  #209
S70driver's Avatar
Good luck just finding the turn signals on EBAY. They are all sold in kits. Unless you can get AutoLampsPlus to sell them seperately. However the turn signals from AutoLampsPlus on EBAY are exactly like mine except they have the orange reflector in them instead of the grey reflector like mine do.
DTMwerks is where you want to purcahse them from.
Comparrison
AutoLampsPlus (Ebay):
DTMwerks:
Old Apr 26, 2007 | 12:06 PM
  #210
you can get black or clear kits of just teh turn signals for $80 shipped
Old Apr 26, 2007 | 12:10 PM
  #211
S70driver's Avatar
Where from EBAY?
Yeah AutoLampsPlus is an EBAY seller. But they have the orange reflector in them instead of the grey or black reflector.
Old Apr 26, 2007 | 12:18 PM
  #212
o yeah, lol, my mistake, well either wya, thats last. If I have to have my gauge professionally installed then it wont happen at all. The lowest I have right now is $180-$270
Old Apr 26, 2007 | 12:31 PM
  #213
S70driver's Avatar
Just go out and install it now. Not hard. Also to find the 12v source use the headlight switch on the left hand side of the steering wheel. Find the 12v line in there and tap into it for power. Then run the vaccum PVC line out into the engine and hook it up.
Old Apr 26, 2007 | 12:37 PM
  #214
not quite as simple, to start I need to find the following wire to connect into:
2 x engine ground
2 x 12v (+)
Then I need to connec the green wire to the white wire form the boost sensor.
Also I cannot get the pvc line on the barbs I try and try but they just wont go on. I also dont know how to get into the dash or get out into the engine.
Old Apr 26, 2007 | 12:39 PM
  #215
S70driver's Avatar
2 x engine ground
2 x 12v (+)
Then send your boost gauge back and get a real one. Too much trouble it seems.
Old Apr 26, 2007 | 12:42 PM
  #216
well its not that much harder, basically I figure I will do what I can and have the volvo people hook up the wires. basically the parts I am stuck on are:
getting to the engine
getting into the dash
Old Apr 26, 2007 | 12:49 PM
  #217
S70driver's Avatar
Don't take it to a Volvo dealership more then likely they wont help you out. Most dealerships are not mod friendly. I know mine isn't. Take it to a performance shop around the area.
Also to get at that firewall pass through just get down underneath your steering wheel. There will be a panel that can be let down. There are three star head screws holding it in place. Take those screws out and let the panel drop. Then you should be able to find the firewall pass through I showed you. And I am not talking about the under side of the steering wheel either.
Old Apr 26, 2007 | 12:54 PM
  #218
kk, ill get back to this, out to school for now
Old Apr 26, 2007 | 02:38 PM
  #219
S70driver's Avatar
ok
Old Apr 26, 2007 | 05:45 PM
  #220
ok, back lets see, so looks like trmw I will attempting to install it, if I fail it goes into teh shop. Dont worry, iw ould never take it to a volvo dealer, although the shop is charging me $90 a hour, how muhc more could a dealer be. But anyways, we dont ahve teh performnce shops that actaully install, the ones that do wont touch my volvo. I was wondering, if its 7 psi max, how much do these things ahve to be sealed? for example, the barbs and the pvc hose seem to be extreamly hard to get on (good seal, if I can get it on) The vacuum tip I have I found taht I could stick teh hose in one side and the barb in teh other, its a pretty tight seal, but not as tight as sticking the pvc on the hose directly. So would you say that 7 psi is a great amount of pressure. I can get the pvc on the barbs, but its gonna take awhile.
