just a newbie question....
Old Jul 27, 2006 | 04:30 PM
mrd2689a's Avatar
Default just a newbie question....
hi everyone this is my first post on this forum. I'm 17 years old and I recently got a great deal on a '98 S70 non-turbo ($3,000 w/70,800 miles). I got the great deal from an old neighbor of mine. Anyway, I need to replace the timing belt, and I have researched online how to do this. It actually doesn't seem that hard. I found great guides at:
http://www.babcox.com/editorial/ic/ic60326.htm
and
http://www.volvospeed.com/Repair/timingbelt.php
I'm just hoping that my car has a hydraulic tensioner (I haven't checked it yet), because it sounds a lot easier to work with. While I am doing that t-belt, I figured that I would check the water pump, and replace the tensioner. Here is my question: in regards to replacing the water pump, I have read that you should only replace it if there is leaking or if it is weeping. What is "weeping"? I just want to know this so if it is weeping, I can replace it right there. Also, is it worth replacing the idler pulley? Thanks for reading this, and thanks for your help in advance.
Matt
Old Jul 28, 2006 | 12:04 AM
Default RE: just a newbie question....
Yes replace the Idler pulley.
By weaping I usually mean slow leaking. Look at the Bottom of the Water pump. You will see a steel Plug pushed into the bottom of it. See if it looks like it is leaking at all. Or if you see a white Scaley build up it is leaking replace it.
Old Jul 28, 2006 | 12:25 AM
mrd2689a's Avatar
Hey tech
Thanks for getting back to me so quickly. Thanks for you feedback, it's exactly what I was looking for. So weaping = leaking very slowly. Thanks!!
Old Dec 17, 2006 | 03:02 PM
OvloV 13's Avatar
Subscribing for future reference
Robert Carter
Jun 27, 2014 10:39 PM
Titch79
Jul 15, 2012 07:50 AM
acmeanvil
Mar 30, 2011 05:31 PM
dan01247
Apr 12, 2008 08:11 PM
wyzard
Feb 28, 2006 12:32 AM
